![]() | Home > Puma (Tdci) > Is this OK - Rear Differential Backlash |
Andy344590 Member Since: 25 Jan 2025 Location: Aberdeen Posts: 20 ![]() ![]() ![]() |
2014 90 Puma 2.2 - I replaced the halfshafts for LOF solid and found a lot of debris in the hub (https://www.defender2.net/forum/topic95141.html), so following forum advice i have just changed the wheel bearings.
When refitting the hub i checked the backlash in the diff as part of 'the clunk' chasing and felt approx 5-6mm of backlash in the rear differential, which may be normal, but got me wondering if this is OK. What are your thoughts on this. The handbrake was on and I checked there was no movement in the propshafts when marking the disc ![]() Click image to enlarge |
Thanks Landy Andy, I will see what it like using that method. Stilll learning about 90, probably will be for a long time yet
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 21015 ![]() ![]() |
You always get some backlash, I seem to recall anything over about 10 degrees is a concern.
But don’t quote me exactly on that, it’s worth checking wheel bearings as well for any horizontal or vertical play while you are there. I wouldn’t worry too much personally. ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
Accidental double post* ____\We|Will|Win/___
