![]() | Home > Puma (Tdci) > JLR SDD Tool |
Angus_Beef Member Since: 30 Apr 2015 Location: Oslo Posts: 434 ![]() ![]() ![]() |
Im quite curious about this as well and when I google, get a fair few results.
Which one did you order and whats the thought behind it? Roaming around 🇳🇴🇨🇠|
itsdashy Member Since: 20 May 2021 Location: Reading Posts: 82 ![]() ![]() ![]() |
This does seem to be a bit of a minefield as it is with most cloned cables.
Easiest way I've found is to get a dedicated laptop. I use an old Lenovo circa 2012 that accepts 16GB ram and a decent size SSD, good for Virtualbox and not stabbing yourself waiting for it to do something. DVD and a serial port are also a massive bonus. Universal laptop car and mains charger. https://www.aliexpress.com/item/1005002365361753.html I'm currently awaiting a V160 cable from https://www.obdexpress.co.uk/wholesale/jlr...rover.html Various versions of IDS/DSS from the Jag thead https://www.jaguarforum.com/threads/jaguar...ll.108460/ [/url] |
matchap801 Member Since: 05 Aug 2021 Location: Somerset Posts: 120 ![]() ![]() ![]() |
Hi all. I use a Mongoose Cable from eBay and v160 of the SDD software. I couldn’t get the VM aware software to work with the cable, but the cable came with a useful CD!
Have managed to sort a few issues on my 2009 90 CSW. I do have a few questions though? 1. Does anyone know how to extract the EKA code using the SDD? 2. When I go into the security settings (can’t give any more info as away with work at the moment) it asks for a security code? Does anyone know what this is or how to get it? Good luck all with your endeavours and tinkering. Mat 2009 Defender 90 CSW 2.4 TDCI. Ex Army Mechanic still living the dream. |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2516 ![]() ![]() |
To put into context, we started conversing on this subject in another topic https://www.defender2.net/forum/topic82813.html
However we thought we really should hold the conversation under a separate topic with an appropriate title. The conversation went like this.
Now everyone is up to speed. I think this bit of research could really come up trumps in the end. |
landhank Member Since: 27 Oct 2021 Location: RLP Posts: 37 ![]() ![]() |
I ordered a V160 cable as well and because it should come with the software ill try to run it on an older laptop ive already here. Iam always on the search for a good diagnostic tool for an 2.2l engine. Ok. Its to good to be true to get a system for less than 100€, but thats why ill try to find out. |
Right. My cable has arrived and I have made it work on the latest x64 Win 10 build. I'll document this and give links later.
However, I'm trying to do a VCV and pilot relearn and can't find this anywhere even when using the straight engineers interface without the diagnostics. Does anyone know which routine to set off? |
Well done. It’s quite a strange system to use. From what I can see and have rad, there is NOT a VCV relearn process. I did cheat and have paid for the FORSCAN software on IOS and that did the pilot learn! 2009 Defender 90 CSW 2.4 TDCI.
Unfortunately for us 2.2 owners Forscan is but a dream.
Indeed. Away on holiday. I will try and add my SDD experience on my return. Thanks. Mat 2009 Defender 90 CSW 2.4 TDCI.
My cable arrived as well, but unfortunately i wont get it run. Its a Win7 system. Using Internet Explorer 11 it comes up with a localhost problem as soon as i try to get into the diagnostics, using Internet Explorer 9 it says that my bowser wont work with active x and iam not able to fix it. |
There are quite a few good support notes on one of the Jaguar Forums (I am away on holiday so can’t get direct to them). Search for something like — jaguar SDD forum —
It may also be worth typing the error message into Google with Landrover (or Jaguar) SDD. I am sure the error will have been seen and fixed before! 2009 Defender 90 CSW 2.4 TDCI. Ex Army Mechanic still living the dream. |
Just thought I would ask if there are any updates on the SDD tool and if any other forum members have any experience with it.
Yup, I got it all working on Win 10 x64 however it has turned out to be pretty much useless for what I want. It seemingly cannot do injector pilot learn or pump learn. Coupled with the fact it's a nightmare to navigate and understand and you can see why many have bowled in with enthusiasm only to just give up.
I've even unlocked the straight-talking engineer's menu and even that's a head-scratcher. If anyone can point me in the direction of a pump learn it would be handy as I've had all my injectors tested/cleaned and would like to cross this one off the list. |
I tried to use the virtual version 1.38 originally - no joy. Downloaded v1.59 and it worked. Used v1.60 that came with the adapter and it worked well. I tried v1.61 and there were lots of Internet Explorer errors. Tried v1.62 and it works. Following a laptop rebuild have gone back to v1.60 and it all works including the engineers code element for a deeper dive. Laptop is Win 10 x64 latest service packs.
What I have realised is that the functions on my 2009 Puma are very limited - no ABS, TC etc. I did get the injecter learn to function after lots of attempts - engine too hot, cold, mains charger / battery not charged enough. I have also used FORSCAN with a Bluetooth obd plug in- this came with diagnostic software that works on other cars as well. In summary, SDD works for me, but functions are so limited. Good to have in case of real issues though. 2009 Defender 90 CSW 2.4 TDCI. Ex Army Mechanic still living the dream. |
