Home > Puma (Tdci) > JLR SDD Tool
Page 2 of 2 <12
itsdashy
United Kingdom 2012 Defender 90 Puma 2.2 PU Orkney Grey
Oooh where do you go for the injector learn in SSD. Mine's a 2.2 so I'm seriously limited to what actually works.
Trying a Topdon 800BT tomorrow to see if that works.
Post #959491 25th Jul 2022 4:45pm
matchap801
United Kingdom 2009 Defender 90 Puma 2.4 CSW Zermatt Silver
Haven't used it for a while, so from sketchy memory, plug in and login to the vehicle session - picture of the LR with the modules under or decides it. Click on the ECU MODULE, then use the guided sessions.
Look under engine (power plant?) Then select the faults, misfire? Then as you step through it should suggest injector relearn? Won't be able to login for a few weeks to give any .ore info? Sorry. 2009 Defender 90 CSW 2.4 TDCI.
Ex Army Mechanic still living the dream.
Post #959495 25th Jul 2022 4:55pm
matchap801
This may help - from a jaguar forum 2009 Defender 90 CSW 2.4 TDCI.
Post #959496 25th Jul 2022 4:57pm
Page 2 of 2 <12
