![]() | Home > Maintenance & Modifications > New Starter Motor |
Grenadier Member Since: 23 Jul 2014 Location: The foot of Mont Blanc... Posts: 5893 ![]() ![]() ![]() |
OK, thinking ahead, may need a new starter motor and quickly.
Trying to avoid Britpart and AllMakes, but what sort of difference would there be between Bearmach and Bosch. There’s clearly quite a price difference, especially here in France. And forget the LR part, which is topping 500€. But for 150€ between Bearmach and Bosch, is their that much difference. Always happy to pay the higher dollars for the best part, but keen to avoid many extra dollars if there is a good alternative. Finally, does anyone know what the Bosch part number is (as opposed to LR) just in case a Ford supplier can offer me one cheaper than LR websites…. Ta. Monsieur Le Grenadier I've not been everywhere, but it's on my list..... 2011 Puma 110DC - Corris Grey |
ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2964 ![]() ![]() |
Denso is a good choice
Nidge Member Since: 27 Jan 2008 Location: Kildare Ireland Posts: 824 ![]() ![]() ![]() |
I recently changed mine, (2011 2.4) went with the Bosch, was around £200 from Britcar and was listed as OEM at the time.
So far so good and has made a big difference to cold starting, turns over first turn of the key now. |
Thanks all. Just looking at battery and terminals first….. Monsieur Le Grenadier
X4SKP Member Since: 29 Nov 2013 Location: Berkshire Posts: 2304 ![]() ![]() ![]() |
Hello Grenadier
I did mine 5 years ago and went for the LR (Bosch) unit and managed to get discount on this (maybe as I one of the usual suspects at the Parts Counter ![]() 2.4 Puma Starter Motor OEM Land Rover (Bosch) Unit LR025840 My advice is go for a good one as when installed you will really not want to do this again anytime soon... easy to assemble on an engine outside a Defender but a stretch and semi-blind procedure under normal circumstances... doable but at times on the edge. ![]() Click image to enlarge Good Luck... SKIP https://www.defender2.net/forum/topic83242.html |
Thanks all. Fingers crossed it’s just a battery/terminal problem and not the starter motor. Monsieur Le Grenadier
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4812 ![]() ![]() |
€170 (about £146) for a Bosch starter motor from the local auto factors. I have to give them the old one when I get it out. 1982 88" 2.25 diesel
Honeyman Member Since: 02 May 2022 Location: Haarlemmermeer Posts: 58 ![]() ![]() ![]() |
I recently paid €175 for a Hella unit from Winparts.nl - no exchange required. So far so good. Swapping it out was do-able - but not something I’d like to repeat too often…
The studs for the electrical connections on the hella unit have a tapered lead to them (unlike the Bosch original) which made getting the nuts on again afterwards a bit easier - every little advantage helped! |
