Home > Maintenance & Modifications > New Starter Motor
Grenadier
New Starter Motor
OK, thinking ahead, may need a new starter motor and quickly.
Trying to avoid Britpart and AllMakes, but what sort of difference would there be between Bearmach and Bosch. There’s clearly quite a price difference, especially here in France. And forget the LR part, which is topping 500€.
But for 150€ between Bearmach and Bosch, is their that much difference. Always happy to pay the higher dollars for the best part, but keen to avoid many extra dollars if there is a good alternative.
Finally, does anyone know what the Bosch part number is (as opposed to LR) just in case a Ford supplier can offer me one cheaper than LR websites….
Ta. Monsieur Le Grenadier
2011 Puma 110DC - Corris Grey
Post #943127 20th Feb 2022 9:59am
ibexman
Denso is a good choice
Post #943128 20th Feb 2022 10:15am
Dinnu
Not 100% sure about compatibility, but I believe that Citroen was using the same engine, and possibly same starter. Might be more common in France. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #943132 20th Feb 2022 10:29am
Nidge
Ireland 2009 Defender 110 Puma 2.4 HCPU Cairns Blue
I recently changed mine, (2011 2.4) went with the Bosch, was around £200 from Britcar and was listed as OEM at the time.
So far so good and has made a big difference to cold starting, turns over first turn of the key now.
Post #943140 20th Feb 2022 11:49am
Grenadier
Thanks all. Just looking at battery and terminals first….. Monsieur Le Grenadier
Post #943233 21st Feb 2022 9:26am
X4SKP
Hello Grenadier
I did mine 5 years ago and went for the LR (Bosch) unit and managed to get discount on this
(maybe as I one of the usual suspects at the Parts Counter Shocked )
2.4 Puma Starter Motor OEM Land Rover (Bosch) Unit LR025840
My advice is go for a good one as when installed you will really not want to do this again anytime soon... easy to assemble on an engine outside a Defender but a stretch and semi-blind procedure under normal circumstances... doable but at times on the edge.
Good Luck... SKIP
Post #943242 21st Feb 2022 10:10am
Grenadier
Thanks all. Fingers crossed it’s just a battery/terminal problem and not the starter motor. Monsieur Le Grenadier
Post #943411 22nd Feb 2022 8:09am
spudfan
Ireland
€170 (about £146) for a Bosch starter motor from the local auto factors. I have to give them the old one when I get it out. 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #952154 10th May 2022 1:47pm
Honeyman
Netherlands 2011 Defender 130 Puma 2.4 HCPU Sumatra Black
I recently paid €175 for a Hella unit from Winparts.nl - no exchange required. So far so good. Swapping it out was do-able - but not something I’d like to repeat too often…
The studs for the electrical connections on the hella unit have a tapered lead to them (unlike the Bosch original) which made getting the nuts on again afterwards a bit easier - every little advantage helped!
Post #952164 10th May 2022 3:12pm
