Home > Maintenance & Modifications > Am I imagining it? Wheel spacers…. |
pjm-84 Member Since: 12 Apr 2021 Location: Hampshire Posts: 642 |
Probably flex in the wheel bolts!
(Levers, as you're 30mm each side further out it will be less harsh) |
12th Sep 2021 8:04pm |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 3997 |
Moving the wheel out has the effect of softening the suspension in roll. The wheel has a longer lever over the spring and anti roll bar. 2007 110 TDCi Station Wagon XS
12th Sep 2021 8:49pm |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3208 |
It is not in your head, as you have increased the distance from the wheel to the spring/shock.
But you should not feel any difference when both wheels on an axle go through a bump at the same time, such as over a speed bump. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
12th Sep 2021 9:52pm |
derbywill Member Since: 25 Mar 2010 Location: Derbyshire Posts: 539 |
When I fitted mine years ago, it was instantly noticeable that it handled and drove differently but much better than stock!
Cheers Will 2005 90 XS 1954 86'' Series 1 tilt |
12th Sep 2021 10:18pm |
Pacha Member Since: 23 Feb 2020 Location: North Yorkshire Posts: 772 |
Increased wheel base. Rgds.
Chris |
12th Sep 2021 11:10pm |
pilsburypie Member Since: 19 Jul 2021 Location: Birmingham Posts: 173 |
Glad I’m not going mad. A noticeable difference for a mere 60mm wider stance combined.
12th Sep 2021 11:32pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 16879 |
I doubt it has got any longer! |
13th Sep 2021 12:18am |
I meant track................obvs. Rgds. Chris |
13th Sep 2021 8:41am |
Does that mean I now have a defender 112?
13th Sep 2021 10:05am |
Better than 109. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
14th Sep 2021 3:30pm |
