Home > Maintenance & Modifications > Am I imagining it? Wheel spacers….
pilsburypie
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Corris Grey
I’ve just added some 30mm wheel spacers to my 110. Look brilliant. Nothing too lary but fill the arches nicely.
However, I’m certain the ride quality has improved. Much smoother and comfy. I’m not talking about hard driving or cornering, I drive very conservatively……. Just feels better.
I can’t imagine why this would be the case but a great side effect even if it’s in my head.
Post #921201 12th Sep 2021 7:11pm
pjm-84
Probably flex in the wheel bolts!
(Levers, as you're 30mm each side further out it will be less harsh)
Post #921209 12th Sep 2021 8:04pm
Bluest
Moving the wheel out has the effect of softening the suspension in roll. The wheel has a longer lever over the spring and anti roll bar. 2007 110 TDCi Station Wagon XS
Post #921211 12th Sep 2021 8:49pm
Dinnu
It is not in your head, as you have increased the distance from the wheel to the spring/shock.
But you should not feel any difference when both wheels on an axle go through a bump at the same time, such as over a speed bump. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #921221 12th Sep 2021 9:52pm
derbywill
England 2005 Defender 90 Td5 XS CSW Java Black
When I fitted mine years ago, it was instantly noticeable that it handled and drove differently but much better than stock!
Will 2005 90 XS
1954 86'' Series 1 tilt
1968 88” 2A 200tdi
2002 110 Hardtop
Post #921223 12th Sep 2021 10:18pm
Pacha
United Kingdom 2008 Defender 90 Puma 2.4 HT Stornoway Grey
Increased wheel base. Rgds.
Chris
Post #921227 12th Sep 2021 11:10pm
pilsburypie
Glad I’m not going mad. A noticeable difference for a mere 60mm wider stance combined.
Post #921228 12th Sep 2021 11:32pm
Question I doubt it has got any longer! Rolling with laughter
Post #921233 13th Sep 2021 12:18am
Pacha
Embarassed
I meant track................obvs. Whistle Rolling Eyes Rgds.
Chris
Post #921247 13th Sep 2021 8:41am
pilsburypie
Does that mean I now have a defender 112?
Post #921258 13th Sep 2021 10:05am
Dinnu
Better than 109. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #921445 14th Sep 2021 3:30pm
