![]() | Home > Maintenance & Modifications > Am I imagining it? Wheel spacers…. |
pjm-84 Member Since: 12 Apr 2021 Location: Hampshire Posts: 714 ![]() ![]() |
Probably flex in the wheel bolts!
(Levers, as you're 30mm each side further out it will be less harsh) |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4337 ![]() ![]() ![]() |
Moving the wheel out has the effect of softening the suspension in roll. The wheel has a longer lever over the spring and anti roll bar. 2007 110 TDCi Station Wagon XS
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3635 ![]() ![]() ![]() |
It is not in your head, as you have increased the distance from the wheel to the spring/shock.
But you should not feel any difference when both wheels on an axle go through a bump at the same time, such as over a speed bump. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
derbywill Member Since: 25 Mar 2010 Location: Derbyshire Posts: 567 ![]() ![]() ![]() |
When I fitted mine years ago, it was instantly noticeable that it handled and drove differently but much better than stock!
Cheers Will 2005 90 XS 1954 86'' Series 1 tilt 1968 88” 2A 200tdi 2002 110 Hardtop |
Pacha Member Since: 23 Feb 2020 Location: North Yorkshire Posts: 781 ![]() ![]() ![]() |
Increased wheel base. Rgds.
Chris |
pilsburypie Member Since: 19 Jul 2021 Location: Birmingham Posts: 176 ![]() ![]() ![]() |
Glad I’m not going mad. A noticeable difference for a mere 60mm wider stance combined.
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17996 ![]() ![]() ![]() |
![]() I meant track................obvs. ![]() ![]() Chris |
Does that mean I now have a defender 112?
Better than 109. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
