Home > Puma (Tdci) > Non starter, help needed.
diduan
Bulgaria
Mine was always a non starter, but until now I managed to make it work by disconnecting the battery, but now Evil or Very Mad
2011 2.4 tdci 145k km
I came back home yesterday evening after a long trip and this morning it didn't want to start any more.
Any help is appreciated. Defender 110 SW MY2011 2.4tdci decat, no EGR
Jeep Wrangler YJ 1990 4.0. Front 78' Dana 60, Rear CUCV 14 bolt
Post #905110 26th May 2021 3:13pm
Angus_Beef
Norway 2015 Defender 110 Puma 2.2 SW Corris Grey
looks like the ignition switch has gone bad Roaming around 🇳🇴🇨🇭
Post #905113 26th May 2021 3:32pm
Yeah, I'd suggest ignition switch, too. It's a relatively common failing, unfortunately. Darren
Post #905150 26th May 2021 5:45pm
Ianh
Probably as above, but also worth checking if all connections to the ignition switch are making a good contact
Post #905171 26th May 2021 7:10pm
diduan
Bulgaria
Thank you community Thumbs Up
I will check if there is a loose connection somewhere, in doubt I will order a new ignition switch.
It's kind of silly but the truck grew on me (it has excelled in so many jobs) and I will fix it. It is my "swiss knife" multi purpose tool I don't want to miss any more. Very Happy Defender 110 SW MY2011 2.4tdci decat, no EGR
Post #905179 26th May 2021 7:35pm
jope
Norway 2011 Defender 110 Puma 2.4 Black LE Java Black
double check battery connections and earth point for starter
Post #905465 28th May 2021 11:53am
boxoftricks
United Kingdom 2011 Defender 110 Puma 2.4 USW Zermatt Silver
From experience only buy a genuine new ignition switch. They do one that comes with new barrels for the doors so you still have one key entry.
Post #905469 28th May 2021 12:21pm
The ignition switch is a separate module that fixes to the end of the barrel. There's no need to change locks or keys when swapping this switch. Darren
Post #905472 28th May 2021 12:34pm
Fernando
Argentina 2008 Defender 110 Puma 2.4 SW Bonatti Grey
The cables that carry current to the starter motor tend to loosen, I would check that !!!
Post #905481 28th May 2021 2:47pm
diduan
Bulgaria
It seems I have to remove the complete dash with everything in order to have access to the shear bolts. I will try to bore them through the plastic with a long bit, hope it will work. Defender 110 SW MY2011 2.4tdci decat, no EGR
Post #905510 28th May 2021 5:31pm
Scotm
Scotland 2012 Defender 110 Puma 2.2 SW Orkney Grey
Use a dremmel to cut a slot in them and use a socket with flat screw driver head.
Or order a replacement lower bracket and just cut through it with the dremmel.
Post #905545 28th May 2021 8:46pm
diduan
Bulgaria
I will follow your suggestion, sounds promising. 😊 Defender 110 SW MY2011 2.4tdci decat, no EGR
Post #905575 29th May 2021 6:45am
diduan
Bulgaria
The dremmel tool didn't do it, because the bolt head was too deep inside.
I just drilled through the plastic part and used ez extractor.
Here is the ignition switch.
New ignition switch ordered Thumbs Up Defender 110 SW MY2011 2.4tdci decat, no EGR
Post #905588 29th May 2021 9:22am
Metal Tim
United Kingdom 2011 Defender 110 Puma 2.4 USW Loire Blue
Hi Guys,
I am experiencing the same problem but my Landy will crank but will not fire have fitted new cam & crank shaft sensors, new battery. removed the As10 alarm box and fitted a special that by passes the immobilizer so that it makes it easier to find the fault. My Landy is a 2011 with a 2.4 Puma engine what i am looking for is a Pinout wiring diagram for the ECU can anyone help me or point me in the right direction please
Post #912492 15th Jul 2021 12:32pm
