Home > Puma (Tdci) > Non starter, help needed. |
Angus_Beef Member Since: 30 Apr 2015 Location: Oslo Posts: 434 |
looks like the ignition switch has gone bad Roaming around 🇳🇴🇨ðŸ‡
26th May 2021 3:32pm |
Yeah, I'd suggest ignition switch, too. It's a relatively common failing, unfortunately. Darren
26th May 2021 5:45pm |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 1796 |
Probably as above, but also worth checking if all connections to the ignition switch are making a good contact
26th May 2021 7:10pm |
diduan Member Since: 13 Oct 2016 Location: Central Balkan Posts: 260 |
Thank you community
I will check if there is a loose connection somewhere, in doubt I will order a new ignition switch. It's kind of silly but the truck grew on me (it has excelled in so many jobs) and I will fix it. It is my "swiss knife" multi purpose tool I don't want to miss any more. Defender 110 SW MY2011 2.4tdci decat, no EGR Jeep Wrangler YJ 1990 4.0. Front 78' Dana 60, Rear CUCV 14 bolt |
26th May 2021 7:35pm |
jope Member Since: 28 Jul 2010 Location: Toten Posts: 11 |
double check battery connections and earth point for starter
28th May 2021 11:53am |
boxoftricks Member Since: 06 Feb 2019 Location: Home Counties Posts: 745 |
From experience only buy a genuine new ignition switch. They do one that comes with new barrels for the doors so you still have one key entry.
28th May 2021 12:21pm |
The ignition switch is a separate module that fixes to the end of the barrel. There's no need to change locks or keys when swapping this switch. Darren
28th May 2021 12:34pm |
Fernando Member Since: 25 Oct 2017 Location: CABA Posts: 86 |
The cables that carry current to the starter motor tend to loosen, I would check that !!!
28th May 2021 2:47pm |
Click image to enlarge It seems I have to remove the complete dash with everything in order to have access to the shear bolts. I will try to bore them through the plastic with a long bit, hope it will work. Defender 110 SW MY2011 2.4tdci decat, no EGR Jeep Wrangler YJ 1990 4.0. Front 78' Dana 60, Rear CUCV 14 bolt |
28th May 2021 5:31pm |
Scotm Member Since: 28 Feb 2014 Location: Aberdeenshire Posts: 645 |
Use a dremmel to cut a slot in them and use a socket with flat screw driver head.
Or order a replacement lower bracket and just cut through it with the dremmel. |
28th May 2021 8:46pm |
I will follow your suggestion, sounds promising. 😊 Defender 110 SW MY2011 2.4tdci decat, no EGR
29th May 2021 6:45am |
The dremmel tool didn't do it, because the bolt head was too deep inside.
Click image to enlarge I just drilled through the plastic part and used ez extractor. Click image to enlarge Here is the ignition switch. Click image to enlarge Click image to enlarge New ignition switch ordered Defender 110 SW MY2011 2.4tdci decat, no EGR Jeep Wrangler YJ 1990 4.0. Front 78' Dana 60, Rear CUCV 14 bolt |
29th May 2021 9:22am |
Metal Tim Member Since: 15 Jul 2021 Location: North Yorkshire Posts: 1 |
Hi Guys,
I am experiencing the same problem but my Landy will crank but will not fire have fitted new cam & crank shaft sensors, new battery. removed the As10 alarm box and fitted a special that by passes the immobilizer so that it makes it easier to find the fault. My Landy is a 2011 with a 2.4 Puma engine what i am looking for is a Pinout wiring diagram for the ECU can anyone help me or point me in the right direction please |
15th Jul 2021 12:32pm |
