![]() | Home > Puma (Tdci) > Non starter, help needed. |
Angus_Beef Member Since: 30 Apr 2015 Location: Oslo Posts: 434 ![]() ![]() ![]() |
looks like the ignition switch has gone bad Roaming around 🇳🇴🇨🇭
Yeah, I'd suggest ignition switch, too. It's a relatively common failing, unfortunately. Darren
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2421 ![]() ![]() |
Probably as above, but also worth checking if all connections to the ignition switch are making a good contact
diduan Member Since: 13 Oct 2016 Location: Central Balkan Posts: 260 ![]() ![]() |
Thank you community
![]() I will check if there is a loose connection somewhere, in doubt I will order a new ignition switch. It's kind of silly but the truck grew on me (it has excelled in so many jobs) and I will fix it. It is my "swiss knife" multi purpose tool I don't want to miss any more. ![]() Jeep Wrangler YJ 1990 4.0. Front 78' Dana 60, Rear CUCV 14 bolt |
jope Member Since: 28 Jul 2010 Location: Toten Posts: 11 ![]() ![]() ![]() |
double check battery connections and earth point for starter
boxoftricks Member Since: 06 Feb 2019 Location: Home Counties Posts: 748 ![]() ![]() ![]() |
From experience only buy a genuine new ignition switch. They do one that comes with new barrels for the doors so you still have one key entry.
The ignition switch is a separate module that fixes to the end of the barrel. There's no need to change locks or keys when swapping this switch. Darren
Fernando Member Since: 25 Oct 2017 Location: CABA Posts: 96 ![]() ![]() ![]() |
The cables that carry current to the starter motor tend to loosen, I would check that !!!
![]() Click image to enlarge It seems I have to remove the complete dash with everything in order to have access to the shear bolts. I will try to bore them through the plastic with a long bit, hope it will work. Defender 110 SW MY2011 2.4tdci decat, no EGR Jeep Wrangler YJ 1990 4.0. Front 78' Dana 60, Rear CUCV 14 bolt |
Scotm Member Since: 28 Feb 2014 Location: Aberdeenshire Posts: 687 ![]() ![]() ![]() |
Use a dremmel to cut a slot in them and use a socket with flat screw driver head.
Or order a replacement lower bracket and just cut through it with the dremmel. |
I will follow your suggestion, sounds promising. 😊 Defender 110 SW MY2011 2.4tdci decat, no EGR
The dremmel tool didn't do it, because the bolt head was too deep inside.
![]() Click image to enlarge I just drilled through the plastic part and used ez extractor. ![]() Click image to enlarge Here is the ignition switch. ![]() Click image to enlarge ![]() Click image to enlarge New ignition switch ordered ![]() Jeep Wrangler YJ 1990 4.0. Front 78' Dana 60, Rear CUCV 14 bolt |
Metal Tim Member Since: 15 Jul 2021 Location: North Yorkshire Posts: 1 ![]() ![]() ![]() |
Hi Guys,
I am experiencing the same problem but my Landy will crank but will not fire have fitted new cam & crank shaft sensors, new battery. removed the As10 alarm box and fitted a special that by passes the immobilizer so that it makes it easier to find the fault. My Landy is a 2011 with a 2.4 Puma engine what i am looking for is a Pinout wiring diagram for the ECU can anyone help me or point me in the right direction please |
