![]() | Home > Puma (Tdci) > Non starter, help needed. |
| Angus_Beef Member Since: 30 Apr 2015 Location: Oslo Posts: 434
looks like the ignition switch has gone bad Roaming around 🇳🇴🇨ðŸ‡
| LandRoverAnorak Member Since: 17 Jul 2011 Location: Surrey Posts: 11327
Yeah, I'd suggest ignition switch, too. It's a relatively common failing, unfortunately. Darren
| Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2536
Probably as above, but also worth checking if all connections to the ignition switch are making a good contact
| diduan Member Since: 13 Oct 2016 Location: Central Balkan Posts: 260
Thank you community
I will check if there is a loose connection somewhere, in doubt I will order a new ignition switch. It's kind of silly but the truck grew on me (it has excelled in so many jobs) and I will fix it. It is my "swiss knife" multi purpose tool I don't want to miss any more. Jeep Wrangler YJ 1990 4.0. Front 78' Dana 60, Rear CUCV 14 bolt |
| jope Member Since: 28 Jul 2010 Location: Toten Posts: 11
double check battery connections and earth point for starter
| boxoftricks Member Since: 06 Feb 2019 Location: Home Counties Posts: 751
From experience only buy a genuine new ignition switch. They do one that comes with new barrels for the doors so you still have one key entry.
The ignition switch is a separate module that fixes to the end of the barrel. There's no need to change locks or keys when swapping this switch. Darren
| Fernando Member Since: 25 Oct 2017 Location: CABA Posts: 98
The cables that carry current to the starter motor tend to loosen, I would check that !!!
Click image to enlarge It seems I have to remove the complete dash with everything in order to have access to the shear bolts. I will try to bore them through the plastic with a long bit, hope it will work. Defender 110 SW MY2011 2.4tdci decat, no EGR Jeep Wrangler YJ 1990 4.0. Front 78' Dana 60, Rear CUCV 14 bolt |
| Scotm Member Since: 28 Feb 2014 Location: Aberdeenshire Posts: 697
Use a dremmel to cut a slot in them and use a socket with flat screw driver head.
Or order a replacement lower bracket and just cut through it with the dremmel. |
I will follow your suggestion, sounds promising. 😊 Defender 110 SW MY2011 2.4tdci decat, no EGR
The dremmel tool didn't do it, because the bolt head was too deep inside.
Click image to enlarge I just drilled through the plastic part and used ez extractor. Click image to enlarge Here is the ignition switch. Click image to enlarge Click image to enlarge New ignition switch ordered Jeep Wrangler YJ 1990 4.0. Front 78' Dana 60, Rear CUCV 14 bolt |
| Metal Tim Member Since: 15 Jul 2021 Location: North Yorkshire Posts: 1
Hi Guys,
I am experiencing the same problem but my Landy will crank but will not fire have fitted new cam & crank shaft sensors, new battery. removed the As10 alarm box and fitted a special that by passes the immobilizer so that it makes it easier to find the fault. My Landy is a 2011 with a 2.4 Puma engine what i am looking for is a Pinout wiring diagram for the ECU can anyone help me or point me in the right direction please |
