Home > Faults & Fixes (L663) > Intelligent AWD only drives in 2WD
Page 11 of 19 <123 ... 101112 ... 171819>
Digger2000
United Kingdom 2006 Defender 90 Other HT Tonga Green
DSL group IT support Thumbs Up cheers šŸ»
Post #893709 24th Mar 2021 9:32pm
Simon Audi
Thanks
So noise was heat shield
Hope all gets resolved when patch arrives
Post #893710 24th Mar 2021 9:32pm
Digger2000
DSL wrote:
Even better res, easier on the eyes. Thumbs Up
Maybe not. Confused
Sorry thought you had sorted better resolution, will try and see if it will upload better at home Thumbs Up
Post #893711 24th Mar 2021 9:33pm
DSL
It’s not a download thing, it’s a code thing for linking the album. Bit of a PITA but just needs the ā€œnormal_ā€ bit deleted then it’s full res. Whistle
Post #893714 24th Mar 2021 9:37pm
Digger2000
Simon Audi wrote:
Thanks
Yes it was the heat shield and there was someone in the Facebook group with identical spec to mine had the same problem but LRA sorted it out in a home call out on site. Took 2 visits though he bent it too far the other way first time he repaired it Rolling with laughter it’s looking like a first edition 90 with rear differential problem.
Post #893715 24th Mar 2021 9:39pm
Digger2000 wrote:
And now onto my next warranty problem...
SPF is peeling away in various sections of the bodywork this being the worst of them but I’ve inspected the whole vehicle and the application isn’t good the template JLR are using is a bit of a bodge job they don’t fold the wrap round the corners and in many body sections stop short on the edges leaving the cut exposed and vulnerable to peeling. I’ve had an independent installer look at the vehicle he said the wrap is the best on the market but the application is a cowboy job. My dealership have told me to take it to their body shop specialist for inspection.
SSM 75044 - Delamination of the Satin Protective Film (SPF)
https://www.defender2.net/forum/post884105...044#884105
Post #893788 25th Mar 2021 10:45am
Digger2000
Thanks mine isn’t as bad as that one but it is getting worse. I can’t remember what brand they use but it is one of the leading wraps on the market. The template is the problem and most probably the application. I will see what the body shop say but this is an expensive option that should not be peeling straight out of the factory šŸ˜‚
Post #893800 25th Mar 2021 11:02am
Tim in Scotland
I believe that the brand used by LR is Expel ( both my local JLR dealer and the local Expel agent/ franchisee tell me this) . Strangely if you have it done aftermarket you get a warranty for 10 years from Expel but as far as I have been able to find out from my local dealer if you have the Satin Finish film from the factory it only has a 3 year warranty like the rest of the car. Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come
2020 D240 1st Edition in Pangea Green with Acorn interior. Now gone - old faithful, no mechanical issues whatsoever ever but the leaks and rattles all over the place won’t be missed!
Post #893803 25th Mar 2021 11:30am
Digger2000
Yes that’s the one Thumbs Up it’s Expel. Not sure either on the warranty length for it but if it is fitted properly you shouldn’t get any issues. My friend is expel approved installer but I thought going through LR would be best for any warranty issues with the paint, I later found out that my dealership use him for doing customers vehicles. He has a good reputation does Paint protection for luxury yachts.
https://www.instagram.com/p/CHVCbu5AKN6/?igshid=19cluhq9w07ee
I’m going to carry this problem over to the specific thread supacat posted so it doesn’t clutter this thread Thumbs Up
Post #893805 25th Mar 2021 11:52am
Simon Audi
Digger
You have the E Diff?
How is it working?
Mine turns on and off - but its locked much more than I expected on a normal road and not giving it any beans..
Thanks
Post #894384 27th Mar 2021 9:53pm
Digger2000
There’s a fault on the driver display screen. You need to get a software patch installed at the dealership but it won’t be ready until next month. See my job sheets in this thread for details šŸ‘šŸ»
Post #894385 27th Mar 2021 10:00pm
Simon Audi
I thought so - but was not sure if the issue was centre or rear...
I guess it applies to everyone with rear E Diff.
I assume - all functions OK (just the display is the issue?)
The update can not be done over the air?
THANKS
Post #894388 27th Mar 2021 10:12pm
Digger2000
I think it’s both differentials but rear glitches much more than centre.
Not sure if it’s only vehicles with the rear differential or not tbh I know a few other people have the problem but said it’s the torque vectoring working which is incorrect the diffs on the 4x4i main screen don’t do that and the driver display screen 4x4i is supposed to mirror the main screen.
My dealership said it’s a software issue only and that the car is safe to drive as normal.
Not sure why it has to be installed in the service department.
Post #894392 27th Mar 2021 10:53pm
Simon Audi
I just been out to look at lights - and yes both diffs have the issue
I checked just the Cockpit - not main screen..
So are you saying the main screen is OK and its just the dash display thats behaving badly?
THANKS
Post #894396 27th Mar 2021 11:07pm
Digger2000
Yes that’s correct...main screen is fine, the driver display has a fault. The service department said it will be a quick fix once they have the patch literally 20 minutes while I wait.
Post #894400 27th Mar 2021 11:14pm
