Home > Faults & Fixes (L663) > Intelligent AWD only drives in 2WD |
Digger2000 Member Since: 19 Sep 2020 Location: Newcastle Posts: 590 |
DSL group IT support cheers š»
24th Mar 2021 9:32pm |
Simon Audi Member Since: 19 Nov 2020 Location: Newport Posts: 544 |
Thanks
So noise was heat shield Hope all gets resolved when patch arrives |
DSL Member Since: 20 Aug 2007 Location: Wandering the wasteland. Posts: 837 |
Itās not a download thing, itās a code thing for linking the album. Bit of a PITA but just needs the ānormal_ā bit deleted then itās full res.
Click image to enlarge |
24th Mar 2021 9:37pm |
Yes it was the heat shield and there was someone in the Facebook group with identical spec to mine had the same problem but LRA sorted it out in a home call out on site. Took 2 visits though he bent it too far the other way first time he repaired it itās looking like a first edition 90 with rear differential problem. |
24th Mar 2021 9:39pm |
SSM 75044 - Delamination of the Satin Protective Film (SPF) https://www.defender2.net/forum/post884105...044#884105 |
25th Mar 2021 10:45am |
Thanks mine isnāt as bad as that one but it is getting worse. I canāt remember what brand they use but it is one of the leading wraps on the market. The template is the problem and most probably the application. I will see what the body shop say but this is an expensive option that should not be peeling straight out of the factory š
25th Mar 2021 11:02am |
Tim in Scotland Member Since: 23 May 2007 Location: The Land that time forgot Posts: 3751 |
I believe that the brand used by LR is Expel ( both my local JLR dealer and the local Expel agent/ franchisee tell me this) . Strangely if you have it done aftermarket you get a warranty for 10 years from Expel but as far as I have been able to find out from my local dealer if you have the Satin Finish film from the factory it only has a 3 year warranty like the rest of the car. Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come
2020 D240 1st Edition in Pangea Green with Acorn interior. Now gone - old faithful, no mechanical issues whatsoever ever but the leaks and rattles all over the place wonāt be missed! |
25th Mar 2021 11:30am |
Yes thatās the one itās Expel. Not sure either on the warranty length for it but if it is fitted properly you shouldnāt get any issues. My friend is expel approved installer but I thought going through LR would be best for any warranty issues with the paint, I later found out that my dealership use him for doing customers vehicles. He has a good reputation does Paint protection for luxury yachts.
https://www.instagram.com/p/CHVCbu5AKN6/?igshid=19cluhq9w07ee Iām going to carry this problem over to the specific thread supacat posted so it doesnāt clutter this thread |
25th Mar 2021 11:52am |
Digger
You have the E Diff? How is it working? Mine turns on and off - but its locked much more than I expected on a normal road and not giving it any beans.. Thanks |
27th Mar 2021 9:53pm |
Thereās a fault on the driver display screen. You need to get a software patch installed at the dealership but it wonāt be ready until next month. See my job sheets in this thread for details šš»
27th Mar 2021 10:00pm |
I thought so - but was not sure if the issue was centre or rear...
I guess it applies to everyone with rear E Diff. I assume - all functions OK (just the display is the issue?) The update can not be done over the air? THANKS |
27th Mar 2021 10:12pm |
I think itās both differentials but rear glitches much more than centre.
Not sure if itās only vehicles with the rear differential or not tbh I know a few other people have the problem but said itās the torque vectoring working which is incorrect the diffs on the 4x4i main screen donāt do that and the driver display screen 4x4i is supposed to mirror the main screen. My dealership said itās a software issue only and that the car is safe to drive as normal. Not sure why it has to be installed in the service department. |
27th Mar 2021 10:53pm |
I just been out to look at lights - and yes both diffs have the issue
I checked just the Cockpit - not main screen.. So are you saying the main screen is OK and its just the dash display thats behaving badly? THANKS |
27th Mar 2021 11:07pm |
Yes thatās correct...main screen is fine, the driver display has a fault. The service department said it will be a quick fix once they have the patch literally 20 minutes while I wait.
27th Mar 2021 11:14pm |
