Home > Puma (Tdci) > Injector seat cutter. 2.4tdci Puma
Page 2 of 2 <12
Moffett
Ireland 2008 Defender 110 Puma 2.4 XS CSW Stornoway Grey
Well, sent off the injectors and had them tested, all in spec. The Lazer tool really was the job for seat cleaning. I did remove the rocker cover but it would not be necessary to do this to clean the seats on their own. 1000 miles leak free. Let's hope it stays that way.
Post #869203 23rd Nov 2020 7:16pm
hank
Happy days! Just looked at the laser 6101, looks like a rotary wire brush? > 110 XS Double Cab
Post #869205 23rd Nov 2020 7:29pm
Moffett
Pretty much, but the bristles are silicone, so you would have to be fairly persistent to cause any damage. I am not going to say the kit is well constructed etc. as it isn't! But it certainly got the seats and bores squeaky clean. I would not even look at one of the cutting tools again at this point. The Laser kit comes with blanks to block off the injector ports. I used a small vacuum tube to remove the debris. It really was much easier to use. The brushes in my particular kit were prone to loosing bristles, not in the bore but when adjusting them prior to use. I also covered the springs with insulation tape to stop them marking the bores. I tried to take pictures, but I was pretty dirty and there wasn't a lot of light!
Post #869212 23rd Nov 2020 8:00pm
hank
Food for thought if (when) mine need doing again > 110 XS Double Cab
Post #869218 23rd Nov 2020 8:15pm
Page 2 of 2 <12
