Home > In Car Electronics > Focal ES100K speaker fitting clarification
Page 3 of 3 <123
acnorman1
United Kingdom 2013 Defender 90 Puma 2.2 XS CSW Corris Grey
Current state of play overnight at my place...
Where did you folks ground the iBus to?
Thanks!
Post #862149 17th Oct 2020 7:32pm
jwb
United States
I went direct to the negative battery terminal with a slightly longer, thicker gauge, wire.
Post #862155 17th Oct 2020 8:03pm
newton-tony
United Kingdom 2014 Defender 110 Puma 2.2 USW Firenze Red
I have mine under second row of seats and found a handy bolt close by that had a good ground
Post #862167 17th Oct 2020 9:11pm
acnorman1
Thanks guys!
(Un)fortunately exmoortrim talking a month for the carpet set so this is all a low-risk trial before ripping out and having the opportunity for a redo. Not sure if grateful for the extra time tinkering or wish I could get it all done in one!
Post #862178 17th Oct 2020 10:41pm
Speedytrail
United Kingdom 2008 Defender 90 Puma 2.4 SW Aintree Green
HI guys, fitting the es 100 k today (will fit the sub next month) but what is the best switch setting on the cross over box for this install?
Post #875839 2nd Jan 2021 12:19pm
DSC-off
Hi, mine is set at -3db.
The Focals have a reputation for being 'bright', with the high frequecies. Plus the tweeters are in a more direct line to to your ears, so they could do with turning down, compared to the main speakers that are pointing down from the lower dash.
What amp/ sub are you going for?
I've not amped my ES130 's yet.
Post #875840 2nd Jan 2021 12:33pm
acnorman1
I think mine are set to 0 and half the time I’m wondering whether to fish them out and change it. Quite a variable emotion depending on the volume though! I have the Kenwood DMX8019DABS head unit and that allows me a bit of adjustment too. Needless to say trial it in “real life” settings. Sounded flawless in the garage on a quiet Sunday...different story at 30 over potholes and puddles!
Post #875895 2nd Jan 2021 6:04pm
hank
Prior to fitting the sub I found them too bright and adjusted the tweeter crossover switch down to -3db. I left the woofer at flat 0db. After fitting the sub I felt it needed more high frequencies back so adjusted the tweeter back to flat 0db > 110 XS Double Cab
Post #875899 2nd Jan 2021 6:21pm
Speedytrail
Was looking at the focal ibus 2.1 in the MUD under cubby box enclosure.
Post #876169 4th Jan 2021 9:48am
hank
I have a brand new unused enclosure for sale if you need one! > 110 XS Double Cab
Post #876171 4th Jan 2021 10:03am
Speedytrail
Thumbs Up
Post #876173 4th Jan 2021 10:05am
Page 3 of 3 <123
