![]() | Home > In Car Electronics > Focal ES100K speaker fitting clarification |
jwb Member Since: 30 Oct 2012 Location: Los Angeles Posts: 27 ![]() ![]() |
I went direct to the negative battery terminal with a slightly longer, thicker gauge, wire.
newton-tony Member Since: 18 Sep 2016 Location: Wiltshire Posts: 122 ![]() ![]() ![]() |
I have mine under second row of seats and found a handy bolt close by that had a good ground
acnorman1 Member Since: 07 Sep 2016 Location: Yorkshire Posts: 22 ![]() ![]() ![]() |
Thanks guys!
(Un)fortunately exmoortrim talking a month for the carpet set so this is all a low-risk trial before ripping out and having the opportunity for a redo. Not sure if grateful for the extra time tinkering or wish I could get it all done in one! |
Speedytrail Member Since: 13 Aug 2020 Location: GLOUS Posts: 7 ![]() ![]() ![]() |
HI guys, fitting the es 100 k today (will fit the sub next month) but what is the best switch setting on the cross over box for this install?
DSC-off Member Since: 16 Oct 2014 Location: North East Posts: 1481 ![]() ![]() ![]() |
Hi, mine is set at -3db.
The Focals have a reputation for being 'bright', with the high frequecies. Plus the tweeters are in a more direct line to to your ears, so they could do with turning down, compared to the main speakers that are pointing down from the lower dash. What amp/ sub are you going for? I've not amped my ES130 's yet. |
I think mine are set to 0 and half the time I’m wondering whether to fish them out and change it. Quite a variable emotion depending on the volume though! I have the Kenwood DMX8019DABS head unit and that allows me a bit of adjustment too. Needless to say trial it in “real life” settings. Sounded flawless in the garage on a quiet Sunday...different story at 30 over potholes and puddles!
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2341 ![]() ![]() ![]() |
Prior to fitting the sub I found them too bright and adjusted the tweeter crossover switch down to -3db. I left the woofer at flat 0db. After fitting the sub I felt it needed more high frequencies back so adjusted the tweeter back to flat 0db > 110 XS Double Cab
Was looking at the focal ibus 2.1 in the MUD under cubby box enclosure. |
I have a brand new unused enclosure for sale if you need one! > 110 XS Double Cab
