Home > Maintenance & Modifications > Spare wheel mounting in a 110 DC |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2196 |
How about a series LWB mounting bracket which fitted to the tub/capping to hold the wheel in the same sort of orientation as yours?
It does normally sit in a recess in the raised side of the tub in a Series but obviously no good on yours as the recess would intrude into the wheel well too much. Shouldnt be too hard to make up a bracket that fixes to the tub and capping and bolts through the centre of the wheel to hold it. Steve 02' 110 TD5 Double Cab Rebuild Thread 84' 90 3.9 V8 Caged Pickup Build Thread - Now For Sale Mobile Diesel Heater Build Thread |
27th Mar 2020 11:10am |
Grenadier Member Since: 23 Jul 2014 Location: The foot of Mont Blanc... Posts: 5765 |
Voilà:
Click image to enlarge Monsieur Le Grenadier I've not been everywhere, but it's on my list..... 2011 Puma 110DC - Corris Grey |
27th Mar 2020 11:13am |
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2224 |
The factory method is shown below and uses this bracket https://www.lrworkshop.com/diagrams/land-r...nted_53728
Yours was likely removed when somebody fitted the chequer plate > 110 XS Double Cab > Instagram @simonlanemind |
27th Mar 2020 11:20am |
As he said though, his bench seat means that the standard position is not suitable.... 02' 110 TD5 Double Cab Rebuild Thread
27th Mar 2020 11:28am |
Tribord Member Since: 20 Apr 2013 Location: France Posts: 217 |
Grenadier, that is the standard mounting position for a 110DC that I already have, but does not work because I now have a bench seat installed on one side.
rallysteve, thanks I think I have seen the setup you mention a long time ago. Probably doesn't need the recess, so I will look for those capping mounted brackets. |
27th Mar 2020 11:32am |
Have a look at this diagram, should show the bits I am thinking of:
https://www.lrworkshop.com/diagrams/land-r...-wagon_432 You might need a 'chock' or 'tyre saver' under the wheel to stop it wanting to roll though without the recess Steve 02' 110 TD5 Double Cab Rebuild Thread 84' 90 3.9 V8 Caged Pickup Build Thread - Now For Sale Mobile Diesel Heater Build Thread |
27th Mar 2020 11:37am |
Definitely missed that > 110 XS Double Cab > Instagram @simonlanemind |
27th Mar 2020 11:42am |
Thanks for finding that Steve. Looks to be a solid solution, fitting to both tub and capping. I would probably need to modify a little with my straight lining sides, but not a problem. However, I think I prefer to only use the capping as a mounting point. I will have a play with some ideas.
27th Mar 2020 11:48am |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 16857 |
There's always the TUL/TUM/Wolf external side mount option, but you'd have to improvise the brackets.
27th Mar 2020 11:58am |
ibexman Member Since: 13 Dec 2008 Location: kent Posts: 2872 |
How about a defender high capacity mount
27th Mar 2020 12:29pm |
Not cheap but Raptor 4x4 offer this, which may suit:
https://www.ebay.co.uk/itm/Raptor-4x4-Inte...SwPh5ZNv02 Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
27th Mar 2020 12:51pm |
Those options are all quite expensive and many of the parts out of stock. So I went back to my first thought and attached a horizontal bar to the front and rear hoop. To this bar I mounted a bracket and then used some of the original factory parts to secure the wheel. For extra security I could add a short strap to the top, but I don't think it needs it - it seems quite solid as it is.
Click image to enlarge |
27th Mar 2020 7:35pm |
Do you have a few more photos showing the bracket & hoop connectors? I'll dig some photos out ~ I mounted some Unwin track along the top edge of the tub and used one of their pivoting connectors with the OE front wheel plate. Photos added: Cargo rail/tracking Click image to enlarge Unwin connector Click image to enlarge Version 1 with OE wheel plate: Click image to enlarge Version 2 without OE wheel plate: Click image to enlarge Final version: Click image to enlarge Last edited by Supacat on 29th Mar 2020 10:22am. Edited 1 time in total |
28th Mar 2020 5:39pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5416 |
I’ve been looking through my pics but can’t find a photo of it but I just made a T bracket. The top had a clamp that attached to the hood frame and the bottom of it fitted to tub sides using existing holes. Then fixed wheel to that.
28th Mar 2020 6:06pm |
