![]() | Home > Maintenance & Modifications > Spare wheel mounting in a 110 DC |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2242 ![]() ![]() ![]() |
How about a series LWB mounting bracket which fitted to the tub/capping to hold the wheel in the same sort of orientation as yours?
It does normally sit in a recess in the raised side of the tub in a Series but obviously no good on yours as the recess would intrude into the wheel well too much. Shouldnt be too hard to make up a bracket that fixes to the tub and capping and bolts through the centre of the wheel to hold it. Steve 02' 110 TD5 Double Cab Rebuild Thread |
Voilà:
![]() ![]() Click image to enlarge ![]() ![]() ![]() I've not been everywhere, but it's on my list..... 2011 Puma 110DC - Corris Grey |
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2358 ![]() ![]() ![]() |
The factory method is shown below and uses this bracket https://www.lrworkshop.com/diagrams/land-r...nted_53728
Yours was likely removed when somebody fitted the chequer plate ![]() |
As he said though, his bench seat means that the standard position is not suitable.... 02' 110 TD5 Double Cab Rebuild Thread
Tribord Member Since: 20 Apr 2013 Location: France Posts: 220 ![]() ![]() ![]() |
Grenadier, that is the standard mounting position for a 110DC that I already have, but does not work because I now have a bench seat installed on one side.
rallysteve, thanks I think I have seen the setup you mention a long time ago. Probably doesn't need the recess, so I will look for those capping mounted brackets. |
Have a look at this diagram, should show the bits I am thinking of:
https://www.lrworkshop.com/diagrams/land-r...-wagon_432 You might need a 'chock' or 'tyre saver' under the wheel to stop it wanting to roll though without the recess Steve 02' 110 TD5 Double Cab Rebuild Thread |
Definitely missed that ![]() |
Thanks for finding that Steve. Looks to be a solid solution, fitting to both tub and capping. I would probably need to modify a little with my straight lining sides, but not a problem. However, I think I prefer to only use the capping as a mounting point. I will have a play with some ideas.
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17947 ![]() ![]() ![]() |
There's always the TUL/TUM/Wolf external side mount option, but you'd have to improvise the brackets.
ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2967 ![]() ![]() |
How about a defender high capacity mount
Not cheap but Raptor 4x4 offer this, which may suit:
![]() https://www.ebay.co.uk/itm/Raptor-4x4-Inte...SwPh5ZNv02 Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
Those options are all quite expensive and many of the parts out of stock. So I went back to my first thought and attached a horizontal bar to the front and rear hoop. To this bar I mounted a bracket and then used some of the original factory parts to secure the wheel. For extra security I could add a short strap to the top, but I don't think it needs it - it seems quite solid as it is.
![]() Do you have a few more photos showing the bracket & hoop connectors? I'll dig some photos out ~ I mounted some Unwin track along the top edge of the tub and used one of their pivoting connectors with the OE front wheel plate. Photos added: Cargo rail/tracking ![]() Click image to enlarge Unwin connector ![]() Click image to enlarge Version 1 with OE wheel plate: ![]() Click image to enlarge Version 2 without OE wheel plate: ![]() Click image to enlarge Final version: ![]() Click image to enlarge Last edited by Supacat on 29th Mar 2020 10:22am. Edited 1 time in total |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5998 ![]() ![]() |
I’ve been looking through my pics but can’t find a photo of it but I just made a T bracket. The top had a clamp that attached to the hood frame and the bottom of it fitted to tub sides using existing holes. Then fixed wheel to that.
