Home > Maintenance & Modifications > Spare wheel mounting in a 110 DC
Tribord
France 2011 Defender 110 Puma 2.4 XS DCPU Zermatt Silver
Is there a better way to carry/secure than this? It normally has a second strap (temporarily borrowed for something else), but is still not great. I have thought about an attachment (connecting through centre of wheel) on a bar running between the front and rear hoops, but wondering if something already exists before making.
I have a bench seat on the other side, so the standard mounting position does not work.
I don't want to use an external carrier, or the roof rack (tyre is higher than the bars which makes it difficult to carry boats).
Post #821595 27th Mar 2020 10:58am
rallysteve
How about a series LWB mounting bracket which fitted to the tub/capping to hold the wheel in the same sort of orientation as yours?
It does normally sit in a recess in the raised side of the tub in a Series but obviously no good on yours as the recess would intrude into the wheel well too much.
Shouldnt be too hard to make up a bracket that fixes to the tub and capping and bolts through the centre of the wheel to hold it.
Post #821601 27th Mar 2020 11:10am
Grenadier
Voilà:
 Monsieur Le Grenadier
2011 Puma 110DC - Corris Grey
Post #821602 27th Mar 2020 11:13am
hank
The factory method is shown below and uses this bracket https://www.lrworkshop.com/diagrams/land-r...nted_53728
Yours was likely removed when somebody fitted the chequer plate
 > 110 XS Double Cab
Post #821605 27th Mar 2020 11:20am
rallysteve
As he said though, his bench seat means that the standard position is not suitable.... 02' 110 TD5 Double Cab Rebuild Thread
Post #821607 27th Mar 2020 11:28am
Tribord
Grenadier, that is the standard mounting position for a 110DC that I already have, but does not work because I now have a bench seat installed on one side.
rallysteve, thanks I think I have seen the setup you mention a long time ago. Probably doesn't need the recess, so I will look for those capping mounted brackets.
Post #821612 27th Mar 2020 11:32am
rallysteve
Have a look at this diagram, should show the bits I am thinking of:
https://www.lrworkshop.com/diagrams/land-r...-wagon_432
You might need a 'chock' or 'tyre saver' under the wheel to stop it wanting to roll though without the recess
Post #821615 27th Mar 2020 11:37am
hank
Definitely missed that Laughing > 110 XS Double Cab
Post #821616 27th Mar 2020 11:42am
Tribord
Thanks for finding that Steve. Looks to be a solid solution, fitting to both tub and capping. I would probably need to modify a little with my straight lining sides, but not a problem. However, I think I prefer to only use the capping as a mounting point. I will have a play with some ideas.
Post #821617 27th Mar 2020 11:48am
There's always the TUL/TUM/Wolf external side mount option, but you'd have to improvise the brackets.
Post #821619 27th Mar 2020 11:58am
ibexman
How about a defender high capacity mount
Post #821631 27th Mar 2020 12:29pm
Not cheap but Raptor 4x4 offer this, which may suit:
https://www.ebay.co.uk/itm/Raptor-4x4-Inte...SwPh5ZNv02 Darren
Post #821636 27th Mar 2020 12:51pm
Tribord
Those options are all quite expensive and many of the parts out of stock. So I went back to my first thought and attached a horizontal bar to the front and rear hoop. To this bar I mounted a bracket and then used some of the original factory parts to secure the wheel. For extra security I could add a short strap to the top, but I don't think it needs it - it seems quite solid as it is.
Post #821694 27th Mar 2020 7:35pm
Thumbs Up
Do you have a few more photos showing the bracket & hoop connectors?
I'll dig some photos out ~ I mounted some Unwin track along the top edge of the tub and used one of their pivoting connectors with the OE front wheel plate.
Photos added:
Cargo rail/tracking
Unwin connector
Version 1 with OE wheel plate:
Version 2 without OE wheel plate:
Final version:
Post #821816 28th Mar 2020 5:39pm
landy andy
I’ve been looking through my pics but can’t find a photo of it but I just made a T bracket. The top had a clamp that attached to the hood frame and the bottom of it fitted to tub sides using existing holes. Then fixed wheel to that.
Post #821819 28th Mar 2020 6:06pm
