Home > Puma (Tdci) > MT82 breather
Page 4 of 4 <1234
Gloucesternige
United Kingdom 2011 Defender 90 Puma 2.4 HT Keswick Green
OK guys, we finally have the definitive answer to all this breather bolt stuff..
I have made a video of a complete strip down of the MT82 gearbox in the Puma Defenders. If you don't want to see the strip down jump forward to around 36 minutes and you'll see the bolt and what it's holding.
Looks like as long as you engage fourth gear and dont touch anything once the bolt is out, you "should" be OK??? Certainly, nothing will drop out.
Please like the video and subscribe to my channel where you can see a complete strip and rebuild of a Puma Defender 2.4.. yes EVERY nut and bolt, not just rust removal and painting of major assemblies.
The video should be live by 20:00 GMT 22nd June.
 Nige
Check out my You Tube channel
https://www.youtube.com/c/Defender90KeswickNigelsLandRoverchannel
Post #838960 22nd Jun 2020 6:51pm
When I removed the breather from my spare box* and then refitted it (about a year after I removed it) it actually wasn't too difficult to refit. I have to say though that if I had seen that video before I removed it, I probably would not have done so.
If you remove the breather with the gearbox otherwise complete, is there anything to stop the semi-circular thing that the breather screws into from rotating round the selector shaft so that the thread is no longer at the top? It obviously can't fall off, but if it inverted itself I imagine it could be very difficult to get it back in place without stripping the box.
There are so many horrible "value-engineered" features on that box! And yes, some of us are listening, and agree with you!
Good work, and a great public service making that video. Thumbs Up
*Incidentally the only reason I removed it was because someone on this forum asked what the thread was. Had I known the full possible consequences, I am not at all sure I would have done so!
Post #838972 22nd Jun 2020 7:01pm
Roger
United Kingdom 2007 Defender 110 Puma 2.4 SW Java Black
Cracking video Nige, very interesting. Thumbs Up
Post #839045 22nd Jun 2020 11:44pm
Gloucesternige
I'll check on reassembly for you bud. I'm sure it cant actually flip over. You could always put an 8mm bar down through the breather hole before removing the bolt. That would stop the lump from spinning. Nige
Post #839047 23rd Jun 2020 1:40am
^^ Now that is a good idea! Why didn't I think of that?
Post #839061 23rd Jun 2020 8:22am
Gloucesternige
And so.. the mod is done.....
 Nige
Post #839127 23rd Jun 2020 1:27pm
Page 4 of 4 <1234
