Home > Puma (Tdci) > Reversing light
sailawaybrad
Reversing light
My reversing light stopped working, so got a new bulb and removed the ladder to get access. Removed the fixture and got to the bulb, existing bulb was fine, but only getting 4.8v through to the socket. Any ideas? Where to start? 2011 2.4 110 Utility Wagon
1963 2.25 88 Soft top
Post #817191 27th Feb 2020 11:05am
Martin
Site Admin
You need to change the reverse switch. Not the easiest job due to access, open ended 22mm spanner needed.
Some helpful threads:
https://www.defender2.net/forum/search.php...ch+spanner  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #817198 27th Feb 2020 11:35am
sailawaybrad
Thanks for the advice! Ordered and fitted new gearbox switch. Was relatively easy to access once I had loosened the gearbox tunnel, giving me enough room to get a deep 22mm socket on to the old switch! Much easier to undo than trying to get to it from the cubby box panel. 2011 2.4 110 Utility Wagon
Post #818662 7th Mar 2020 6:28pm
chrisc2306
Scotland 2011 Defender 90 Puma 2.4 CSW Zambezi Silver
Had the same issue, changed it this morning no problems, the access from underneath isn’t too bad with a 22mm ring spanner, and you can squeeze your hand up to it fairly easy. Definitely recommend this way rather than removing the cubby box etc
Post #857432 22nd Sep 2020 3:15pm
