Home > Puma (Tdci) > Reversing light |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6480 |
You need to change the reverse switch. Not the easiest job due to access, open ended 22mm spanner needed.
Some helpful threads: https://www.defender2.net/forum/search.php...ch+spanner 1988 90 Td5 NAS soft top 2015 D90 XS SW |
27th Feb 2020 11:35am |
sailawaybrad Member Since: 14 May 2016 Location: Nr Exeter Posts: 43 |
Thanks for the advice! Ordered and fitted new gearbox switch. Was relatively easy to access once I had loosened the gearbox tunnel, giving me enough room to get a deep 22mm socket on to the old switch! Much easier to undo than trying to get to it from the cubby box panel. 2011 2.4 110 Utility Wagon
1963 2.25 88 Soft top |
7th Mar 2020 6:28pm |
chrisc2306 Member Since: 02 Jan 2020 Location: Glasgow Posts: 58 |
Had the same issue, changed it this morning no problems, the access from underneath isn’t too bad with a 22mm ring spanner, and you can squeeze your hand up to it fairly easy. Definitely recommend this way rather than removing the cubby box etc
22nd Sep 2020 3:15pm |
