Home > Maintenance & Modifications > Ball Bearing Security
TheShrink
Hi All,
I am not ‘mechanical’ so apologies in advance if my query is silly.
I like the idea of inserting ball bearings in the head of bolts to prevent parts being stolen.
Is this easy to do?
In the event you need to take a part off, how is the bb removed?
Thanks
The Shrink
Post #803027 20th Nov 2019 11:33pm
They're easy enough to insert and difficult, although not impossible to lever out again, which is of course the whole point.
As an aside, I recently came across these on eBay, which appear to be a slightly more elegant solution. I suspect removal would require some very careful drilling:
https://i.ebayimg.com/images/g/BjQAAOSwm~daaF5i/s-l1600.jpg Darren
Post #803029 20th Nov 2019 11:51pm
bankz5152
Id buy the bombproof door hinges instead. Serves the same purpose but you havnt got a total ass of a job when you need a door off.
Post #803035 21st Nov 2019 6:56am
Personally I don't think that the bombproof hinge plates offer any security at all as they assume that the hinges are being unbolted in order to gain access to the vehicle. In practice it is so easy to open the door first that the only reason to unbolt the hinges is to steal the doors, and once they are open the hinge plates do nothing.
Ball bearings are very effective but if securely bonded can take a long time to remove, which is exactly what you want.
Post #803037 21st Nov 2019 8:15am
hank
I appreciate that for some welding is not an option,
However if I were to weld the bolts to the hinge (from behind the hinge to maintain OE appearance), effectively turning the bolts into studs, then this would render the bolts "tamper proof" externally?
Can anybody see a reason why this would not be advised? > 110 XS Double Cab
Post #803040 21st Nov 2019 8:39am
TheShrink
Would someone PM me to explain how a ball bearing can be extracted?
Also, does putting silicone over the heads of bolts work?
Thanks
Post #803042 21st Nov 2019 8:55am
It doesn't address the real issue, the screws which go into the captive nuts in the A posts (and B posts on a 110).
Post #803045 21st Nov 2019 9:15am
Thanks
Balls can usually be removed with great difficulty and a lot of patience. I replaced my ball-bearinged hinges a while back (110 DC, so 4 doors) and it took a variety of tools and about a day of my time to get enough balls out to get the hinges off.
Filling the socket heads of the fasteners is effective and it is still fairly time-consuming to dig out enough to unscrew them, though not in the same league as balls. If you have pin torx 'security' screws you cannot use balls so silicon or similar filler is an easy alternative.
Post #803047 21st Nov 2019 9:24am
hank
Sorry, if these were replaces with conventional nuts > 110 XS Double Cab
Post #803048 21st Nov 2019 9:50am
The problem is that you can't get to the backs of those to use conventional nuts. They're inside the A and B posts. Darren
Post #803049 21st Nov 2019 10:05am
hank
Trying to think back to remember what it's like, am away from my Defender in Saudi Arabia at the moment . Will have to refresh my memory when home over Christmas! > 110 XS Double Cab
Post #803050 21st Nov 2019 10:11am
You can actually get to the B post nuts on a 110/130, but you'd have to cut holes in the bulkhead for the A post.
Post #803058 21st Nov 2019 10:59am
X4SKP
Hello TheShrink
I agree that the door bolts are a worth while security level and easy enough to implement
and probably take the vehicle to a point that put off the opportunist as it adds time to get round this step.
If all doors (and probably the bonnet too) are removed from a Defender, cutting the loom to the
central locking / electric windows in the process, this can potentially result in the vehicle being written off
(there is a post on D2N that ended this way)
I hadn't seen the Torx infills posted by LandRoverAnorak and I would view these as essentially
a 'sealed for life' security step, may ok... but the ball bearings do give you a reverse option.
I haven't needed to do it on the Defender but have needed to remove a component from a bicycle (Brooks saddle)
by drilling out, basically a small drill bit (I used a Dremel) at 3 of the Torx 'end points' and the metal based resin isopon
'gave way'...with some gentle encouragement.
I replaced all Torx bolts with SS versions (site sponsor) used cycle ball bearings to infill I also painted the end result
body colour here is mid process...
Good Luck SKIP
Post #803059 21st Nov 2019 11:03am
Caterham
Thanks
I've been thinking about the silicon option but still haven't got round to it' I'm sure it would suffice in slowing removal down sufficiently. Thumbs Up
Post #803061 21st Nov 2019 11:56am
Paul1275s
United Kingdom 2003 Defender 110 Td5 SW Belize Green
I’m probably just going to drill the head of the bolts to remove the torx profile once bolts are fitted securely. So basically it’s like having a rounded head. I’ve got enough cobalt drill bits and easy-outs if I ever need to remove the doors. Might back up with a ball bearing. At the end of the day my doors are dented to Censored and a bit crusty at the bottom, they’d almost be doing me a favour... 2003 Defender 110 TD5 SW
2003 Caterham 7
2006 Mini Cooper GP
Post #803066 21st Nov 2019 12:14pm
