![]() | Home > Technical > LED light kit issue |
| landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 6059
I assume you have tried wires both ways onto new light fitting?
| leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8584
Filament lights are not polarity sensitive.
LEDs are polarity sensitive. You need to swop the two wires on the rear indicator plug to get it to work. Brendan |
| Timbo66 Member Since: 14 Oct 2018 Location: Leicester Posts: 37
It is plug and play with fitting plugs to fit the original socket.
Do you think this could still be t h e issue?? |
Yes I do.
If you have a decent multimeter, set it to a range like 20 volts DC. Carefully note the orientation of the socket on both rear indicator and measure the voltage on indicating. Chances are one will show a negative voltage and the other a positive voltage. Brendan |
| grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4804
+1 for polarity. Try swapping the wires within the connector
Thank you all for the responses. I'm guessing that as the LED is pre-wired it must be within the wiring on the vehicle.
I will give it a try when I get home tonight and report back!! |
| Roy5695 Member Since: 15 Feb 2014 Location: Cornwall Posts: 1123
If you have a couple bits of wire to make two jumper cables it would be easy to test the theory before committing to cutting plugs off. 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
Instagram - @r22oyp Roy |
You can check this by comparing the wiring on the other side of the vehicle as the wires are colour coded
| rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2243
There is no need to cut plugs off! It us quite easy to remove terminals from Econoseal connectors without damage!
Steve 02' 110 TD5 Double Cab Rebuild Thread |
Thank you all, some really useful info.
Much appreciated. |
Success!!
Swapped the cables over and we have a flash. Thanks again to all that responded. Tim. |
Great news.
| Mcmuffin Member Since: 01 Apr 2014 Location: Antwerp city Posts: 38
problem solved ! But still 1-0 for the factory guys
They will always win ,
| All times are GMT |
