Home > Technical > LED light kit issue
Timbo66
United Kingdom 2008 Defender 90 Puma 2.4 CSW Java Black
LED light kit issue
I have fitted a Wipac led kit to my 2008 Puma. Everything works fine with the exception of the O/S rear indicator.
The unit itself is ok as I've swapped side to side and it works fine. I have tried the old non led light and that works fine.
I have fitted a new flasher relay as supplied with the kit.
Any ideas???
Thanks.
Post #748610 1st Jan 2019 11:44pm
landy andy
I assume you have tried wires both ways onto new light fitting?
Post #748612 1st Jan 2019 11:49pm
leeds
Filament lights are not polarity sensitive.
LEDs are polarity sensitive.
You need to swop the two wires on the rear indicator plug to get it to work.
Brendan
Post #748613 2nd Jan 2019 12:09am
Timbo66
It is plug and play with fitting plugs to fit the original socket.
Do you think this could still be t h e issue??
Post #748614 2nd Jan 2019 12:23am
leeds
Yes I do.
If you have a decent multimeter, set it to a range like 20 volts DC.
Carefully note the orientation of the socket on both rear indicator and measure the voltage on indicating. Chances are one will show a negative voltage and the other a positive voltage.
Brendan
Post #748621 2nd Jan 2019 5:18am
grafty99
+1 for polarity. Try swapping the wires within the connector Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #748635 2nd Jan 2019 9:46am
Timbo66
Thank you all for the responses. I'm guessing that as the LED is pre-wired it must be within the wiring on the vehicle.
I will give it a try when I get home tonight and report back!!
Post #748642 2nd Jan 2019 10:37am
Roy5695
If you have a couple bits of wire to make two jumper cables it would be easy to test the theory before committing to cutting plugs off. 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
Instagram - @r22oyp
Roy
Post #748644 2nd Jan 2019 10:44am
landy andy
You can check this by comparing the wiring on the other side of the vehicle as the wires are colour coded
Post #748647 2nd Jan 2019 10:55am
rallysteve
There is no need to cut plugs off! It us quite easy to remove terminals from Econoseal connectors without damage!
Post #748655 2nd Jan 2019 11:21am
Timbo66
Thank you all, some really useful info.
Much appreciated.
Post #748666 2nd Jan 2019 12:13pm
Timbo66
Success!!
Swapped the cables over and we have a flash.
Thanks again to all that responded.
Tim.
Post #748815 2nd Jan 2019 11:08pm
landy andy
Great news. Thumbs Up Thumbs Up
Post #748830 2nd Jan 2019 11:53pm
Mcmuffin
Belgium 2013 Defender 130 Puma 2.2 HCPU Santorini Black
problem solved ! But still 1-0 for the factory guys
Post #749220 4th Jan 2019 7:16pm
Timbo66
They will always win ,
Post #754085 26th Jan 2019 4:38pm
