Home > Technical > LED light kit issue |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5417 |
I assume you have tried wires both ways onto new light fitting?
1st Jan 2019 11:49pm |
leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8578 |
Filament lights are not polarity sensitive.
LEDs are polarity sensitive. You need to swop the two wires on the rear indicator plug to get it to work. Brendan |
2nd Jan 2019 12:09am |
Timbo66 Member Since: 14 Oct 2018 Location: Leicester Posts: 37 |
It is plug and play with fitting plugs to fit the original socket.
Do you think this could still be t h e issue?? |
2nd Jan 2019 12:23am |
Yes I do.
If you have a decent multimeter, set it to a range like 20 volts DC. Carefully note the orientation of the socket on both rear indicator and measure the voltage on indicating. Chances are one will show a negative voltage and the other a positive voltage. Brendan |
2nd Jan 2019 5:18am |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4784 |
+1 for polarity. Try swapping the wires within the connector 2002 90 Td5 Station Wagon
2nd Jan 2019 9:46am |
Thank you all for the responses. I'm guessing that as the LED is pre-wired it must be within the wiring on the vehicle.
I will give it a try when I get home tonight and report back!! |
2nd Jan 2019 10:37am |
Roy5695 Member Since: 15 Feb 2014 Location: Cornwall Posts: 1123 |
If you have a couple bits of wire to make two jumper cables it would be easy to test the theory before committing to cutting plugs off. 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
Instagram - @r22oyp Roy |
2nd Jan 2019 10:44am |
You can check this by comparing the wiring on the other side of the vehicle as the wires are colour coded
2nd Jan 2019 10:55am |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2198 |
There is no need to cut plugs off! It us quite easy to remove terminals from Econoseal connectors without damage!
Steve 02' 110 TD5 Double Cab Rebuild Thread 84' 90 3.9 V8 Caged Pickup Build Thread - Now For Sale Mobile Diesel Heater Build Thread |
2nd Jan 2019 11:21am |
Thank you all, some really useful info.
Much appreciated. |
2nd Jan 2019 12:13pm |
Success!!
Swapped the cables over and we have a flash. Thanks again to all that responded. Tim. |
2nd Jan 2019 11:08pm |
Great news.
2nd Jan 2019 11:53pm |
Mcmuffin Member Since: 01 Apr 2014 Location: Antwerp city Posts: 38 |
problem solved ! But still 1-0 for the factory guys
4th Jan 2019 7:16pm |
They will always win ,
26th Jan 2019 4:38pm |
