![]() | Home > Puma (Tdci) > Engine stops when I'm driving |
DAZ110 Member Since: 06 Dec 2007 Location: East Sussex Posts: 2065 ![]() ![]() |
Battery connections?
Okan Member Since: 17 Oct 2016 Location: Geneva Posts: 138 ![]() ![]() ![]() |
I will check tomorow morning but normaly I well sealed my battery box so it shouldn't have any corrosion on conectors...
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3677 ![]() ![]() ![]() |
check all earths DEFENDER 90 TDCI XS,
Thanks but could you indicate to me where are all those earth on puma tdci please?
regards |
Battery connections can sometimes come loose, rather than corroded.
Check the battery earth connection under the vehicle is clean and tight. |
Ok I will do it tomorow morning and I ll let you know!
Earth on puma tdci land rover main ones
From battery down too the chassis then to transfer box, next right or left hand side under the vehicle between chassis and the bulkhead earth strap. Last edited by dorsetsmith on 11th Nov 2018 10:23pm. Edited 1 time in total |
mine is left hand drive
Mine has done this once, and it was due to the main relay coming loose under the passenger seat.
Most of the dash lights (save for the battery and oil I think) went out and the gauges went to full scale. It's an easy fix, just tighten up the terminals on the socket and push the relay back in. It's under the driver's seat on a UK vehicle, so I guess that's under the passenger seat on a LHD vehicle. Opposite side to the battery anyway. |
Okay I checked the two earth from battery to chassis to Tbox it was ok.
After that I started for a ride and then all was ok untill I put the heather on 3 and now engine stoped but this time it never started again. I tried to check all fuses and relay. 12volt in the main relay under passenger seat but nothing when turning the key. warning lights and lights are working but nothing on ignition. Now the car is with the mechanic. We will see tomorow. be |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8383 ![]() ![]() ![]() |
Check mulitplug back of engine Cheers
what is it and where is it?
regards |
Has engine harness had become damaged by sitting over & rubbing against pipe work and or engine metal work
