|  | Home > Puma (Tdci) > Engine stops when I'm driving |
| DAZ110 Member Since: 06 Dec 2007 Location: East Sussex Posts: 2067    | Battery connections? | ||
|  11th Nov 2018 8:16pm |
| Okan Member Since: 17 Oct 2016 Location: Geneva Posts: 138      | I will check tomorow morning but normaly I well sealed my battery box so it shouldn't have any corrosion on conectors... | ||
|  11th Nov 2018 8:41pm |
| LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3680      | check all earths DEFENDER 90 TDCI XS,
 I hope everyone is well and your land rovers make you happy | ||
|  11th Nov 2018 8:42pm |
| Okan Member Since: 17 Oct 2016 Location: Geneva Posts: 138      | Thanks but could you indicate to me where are all those earth on puma tdci please?
 regards | ||
|  11th Nov 2018 8:48pm |
| DAZ110 Member Since: 06 Dec 2007 Location: East Sussex Posts: 2067    | Battery connections can sometimes come loose, rather than corroded.
 Check the battery earth connection under the vehicle is clean and tight. | ||
|  11th Nov 2018 8:53pm |
| Okan Member Since: 17 Oct 2016 Location: Geneva Posts: 138      | Ok I will do it tomorow morning and I ll let you know! | ||
|  11th Nov 2018 8:58pm |
| dorsetsmith Member Since: 30 Oct 2011 Location: South West Posts: 4554  | Earth on puma tdci land rover main ones
 From battery down too the chassis then to transfer box, next right or left hand side under the vehicle between chassis and the bulkhead earth strap. Last edited by dorsetsmith on 11th Nov 2018 9:23pm. Edited 1 time in total | ||
|  11th Nov 2018 9:03pm |
| Okan Member Since: 17 Oct 2016 Location: Geneva Posts: 138      | mine is left hand drive | ||
|  11th Nov 2018 9:07pm |
| dorsetsmith Member Since: 30 Oct 2011 Location: South West Posts: 4554  |  | ||
|  11th Nov 2018 10:21pm |
| Cupboard Member Since: 21 Mar 2014 Location: Suffolk Posts: 2971      | Mine has done this once, and it was due to the main relay coming loose under the passenger seat.
 Most of the dash lights (save for the battery and oil I think) went out and the gauges went to full scale. It's an easy fix, just tighten up the terminals on the socket and push the relay back in. It's under the driver's seat on a UK vehicle, so I guess that's under the passenger seat on a LHD vehicle. Opposite side to the battery anyway. | ||
|  11th Nov 2018 11:23pm |
| Okan Member Since: 17 Oct 2016 Location: Geneva Posts: 138      | Okay I checked the two earth from battery to chassis to Tbox it was ok.
 After that I started for a ride and then all was ok untill I put the heather on 3 and now engine stoped but this time it never started again. I tried to check all fuses and relay. 12volt in the main relay under passenger seat but nothing when turning the key. warning lights and lights are working but nothing on ignition. Now the car is with the mechanic. We will see tomorow. be | ||
|  12th Nov 2018 11:36pm |
| jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8491      | Check mulitplug back of engine Cheers
 James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop | ||
|  13th Nov 2018 7:53pm |
| Okan Member Since: 17 Oct 2016 Location: Geneva Posts: 138      | what is it and where is it?
 regards | ||
|  13th Nov 2018 8:11pm |
| dorsetsmith Member Since: 30 Oct 2011 Location: South West Posts: 4554  | Has engine harness had become damaged by sitting over & rubbing against pipe work and or  engine metal work | ||
|  14th Nov 2018 9:29am |
| Posting Rules
