Home > Puma (Tdci) > Engine stops when I'm driving
Okan
Switzerland 2009 Defender 110 Puma 2.4 SW Stornoway Grey
Hello all,
I have a big problem with my 2.4tdci puma one ten. My engine stops when I'm driving. It's not an overheating problem but seems to be more like an electrical problem because sometimes the engine is stoping and starts again. All lights, radio and ignition accessories stops too when it happens. Do you have an idea where to check? It's realy dangerous specially on the road at night with no more lights.
Best regards
Post #739913 11th Nov 2018 8:28pm
DAZ110
Battery connections?
Post #739927 11th Nov 2018 9:16pm
Okan
I will check tomorow morning but normaly I well sealed my battery box so it shouldn't have any corrosion on conectors...
Post #739935 11th Nov 2018 9:41pm
LR90XS2011
check all earths DEFENDER 90 TDCI XS,
Post #739938 11th Nov 2018 9:42pm
Okan
Thanks but could you indicate to me where are all those earth on puma tdci please?
regards
Post #739940 11th Nov 2018 9:48pm
DAZ110
Battery connections can sometimes come loose, rather than corroded.
Check the battery earth connection under the vehicle is clean and tight.
Post #739943 11th Nov 2018 9:53pm
Okan
Ok I will do it tomorow morning and I ll let you know!
Post #739946 11th Nov 2018 9:58pm
dorsetsmith
Earth on puma tdci land rover main ones
From battery down too the chassis then to transfer box, next right or left hand side under the vehicle between chassis and the bulkhead earth strap.
Post #739949 11th Nov 2018 10:03pm
Okan
mine is left hand drive
Post #739950 11th Nov 2018 10:07pm
dorsetsmith
Cool
Post #739958 11th Nov 2018 11:21pm
Cupboard
Mine has done this once, and it was due to the main relay coming loose under the passenger seat.
Most of the dash lights (save for the battery and oil I think) went out and the gauges went to full scale.
It's an easy fix, just tighten up the terminals on the socket and push the relay back in. It's under the driver's seat on a UK vehicle, so I guess that's under the passenger seat on a LHD vehicle. Opposite side to the battery anyway.
Post #739968 12th Nov 2018 12:23am
Okan
Okay I checked the two earth from battery to chassis to Tbox it was ok.
After that I started for a ride and then all was ok untill I put the heather on 3 and now engine stoped but this time it never started again. I tried to check all fuses and relay. 12volt in the main relay under passenger seat but nothing when turning the key. warning lights and lights are working but nothing on ignition.
Now the car is with the mechanic. We will see tomorow.
be
Post #740212 13th Nov 2018 12:36am
jst
Check mulitplug back of engine Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #740354 13th Nov 2018 8:53pm
Okan
what is it and where is it?
regards
Post #740360 13th Nov 2018 9:11pm
dorsetsmith
Has engine harness had become damaged by sitting over & rubbing against pipe work and or engine metal work
Post #740459 14th Nov 2018 10:29am
