![]() | Home > Puma (Tdci) > New gear levers |
L90Andy Member Since: 29 May 2014 Location: Stratford-Upon-Avon Posts: 728 ![]() ![]() ![]() |
Pull like hell from inside, it'll pop off 👍 Instagram: L90andy
My 1984 Ninety: http://www.defender2.net/forum/topic56071.html - SOLD! My 2015 Defender: http://www.defender2.net/forum/topic39625.html - SOLD! |
edo Member Since: 20 Aug 2018 Location: Devon Posts: 379 ![]() ![]() |
Cool, ok.
And the glue? Edit: "primer adhesion promoter"?? |
No idea I'm afraid. That wasn't included when I did my genuine ones.
Main gear lever has clips as it retention, transfer box is an interference fit. Instagram: L90andy My 1984 Ninety: http://www.defender2.net/forum/topic56071.html - SOLD! My 2015 Defender: http://www.defender2.net/forum/topic39625.html - SOLD! |
HardCharger Member Since: 03 Mar 2013 Location: Manila Posts: 786 ![]() ![]() ![]() |
From what I was told, the glue is there in the event the plastic underthingies on the levers come off, you can use the glue to hold the new levers in place.
Main gear knob on easy peasy. Transfer knob refuses to budge!
Put the T-Case in neutral then pull the lever off after you separate it from the boot.
