Home > Puma (Tdci) > New gear levers
edo
New gear levers
Got some nice leather gear and transfer levers to fit.
Found a vid on removal of main gear lever which seems easy enough.
What is the rick with the transfer lever?
Finally both have come with superglue. Perplexed why I would need this on either?
Post #736735 25th Oct 2018 7:25pm
L90Andy
United Kingdom 2006 Defender 90 Td5 SW Zambezi Silver
Pull like hell from inside, it'll pop off 👍 Instagram: l90andy
2006 Land Rover 90 TD5 CSW Silver Edition
My 1984 Ninety: http://www.defender2.net/forum/topic56071.html - SOLD!
My 2015 Defender: http://www.defender2.net/forum/topic39625.html - SOLD!
Post #736738 25th Oct 2018 7:31pm
edo
Cool, ok.
And the glue?
Edit: "primer adhesion promoter"??
Post #736739 25th Oct 2018 7:32pm
L90Andy
No idea I'm afraid. That wasn't included when I did my genuine ones.
Main gear lever has clips as it retention, transfer box is an interference fit. Instagram: l90andy
Post #736741 25th Oct 2018 7:42pm
HardCharger
2011 Defender 110 Puma 2.4 SW Stornoway Grey
From what I was told, the glue is there in the event the plastic underthingies on the levers come off, you can use the glue to hold the new levers in place.
Post #736806 26th Oct 2018 2:27am
edo
Main gear knob on easy peasy. Transfer knob refuses to budge!
Post #737014 27th Oct 2018 11:10am
HardCharger
Put the T-Case in neutral then pull the lever off after you separate it from the boot.
Post #737168 28th Oct 2018 11:05am
