![]() | Home > Technical > 200 tdi Alternator Problems - help please. |
| dorsetsmith Member Since: 30 Oct 2011 Location: South West Posts: 4554 |
What wire colour do you have for Alternator wiring
two brown 6mm2 wire one brown yellow 1.5mm2 https://www.defendersource.com/forum/f6/20...97345.html Last edited by dorsetsmith on 28th Aug 2018 1:42pm. Edited 4 times in total |
| HK07 Member Since: 15 Dec 2016 Location: Hampshire Posts: 755
Thanks for the speedy response.
Sorry but that does not mean anything to me. 2007 90 Puma - Love it - Best car I have ever owned. 1989 Ninety 200tdi - Love it - Second best car I have ever owned. 1951 80" Series 1 - Love it - Third best car I have ever owned. |
| Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6736
The top terminal/stud with the "W" next to it is for a rev counter.
The battery light is connected to the smaller wire on the bottom set of three spades (two of which are wrapped in white tape). The red spade with the (hopefully) BROWN with YELLOW wire is the battery warning light feed. Your wiring has definitely been mucked about with - the proper alternator plug is missing. The two white-wrapped spades and the warning light spade should be in a proper plug: https://polevolt.co.uk/acatalog/Lucas-Alte...tml#SID=53 1988 90 Td5 NAS soft top
2015 D90 XS SW |
HK07 sorry on the mobile phone start with |
Thanks guys, so the dangling wire is probably from when the alternator came from a different vehicle that had a revcounter.
Why is my battery light on permanently? If it wasn't on at all I would say a connection fault but with it on permanently I really am confused. Much obliged for all the advice. Cheers HK07 2007 90 Puma - Love it - Best car I have ever owned. 1989 Ninety 200tdi - Love it - Second best car I have ever owned. 1951 80" Series 1 - Love it - Third best car I have ever owned. |
Click image to enlarge Click image to enlarge you my have problem with your alternator regulator or brushes |
Thanks dorsetsmith.
That's explains the system very well, now we have to find out why it's not working. 2007 90 Puma - Love it - Best car I have ever owned. 1989 Ninety 200tdi - Love it - Second best car I have ever owned. 1951 80" Series 1 - Love it - Third best car I have ever owned. |
Don't I feel silly!!!
Took her on a bit of a drive today, and when the revs rise a little the light goes out. Thanks anyway guys 1989 Ninety 200tdi - Love it - Second best car I have ever owned. 1951 80" Series 1 - Love it - Third best car I have ever owned. |
It's not had an LED bulb fitted in that position by any chance?
2015 D90 XS SW |
Don't think so - I'll check.it though. 2007 90 Puma - Love it - Best car I have ever owned.
OK I just wonder if the alternator is not being excited correctly on the D+ (warning light) wire and so it's taking more revs to get it to kick in and start charging.
2015 D90 XS SW |
| All times are GMT |
