Home > Technical > 200 tdi Alternator Problems - help please.
HK07
England 2007 Defender 90 Puma 2.4 HT Cairns Blue
Hi Guys
So working on my project rebuild and I have a problem with the alternator wiring.
When we took the engine out I seem to remember it having a black wire from the top terminal in the picture below to the adjacent engine mount. I do remember thinking that needs securing better than that and took it off but never took a picture first Banging Head
Fast forward a year and I can't quite remember what went where, and I don't want to do any damage.
At the moment it starts and runs fine, but the battery light is on on the dash and I presume we are not charging the battery.
Can I reconnect a wire from that terminal to said engine mount or will that do damage? All the alternators wiring is rough and needs tiding up before the wings go back on.
I would have thought it would get its earth from the bolts holding it on to the block.
Thanks in advance. 2007 90 Puma - Love it - Best car I have ever owned.
1989 Ninety 200tdi - Love it - Second best car I have ever owned.
1951 80" Series 1 - Love it - Third best car I have ever owned.
Post #725796 28th Aug 2018 1:07pm
dorsetsmith
What wire colour do you have for Alternator wiring Question
two brown 6mm2 wire Question with large spades terminal B+ out put from Alternator to battery
one brown yellow 1.5mm2 Question small spade terminal D+ from dash battery lamp
https://www.defendersource.com/forum/f6/20...97345.html
Post #725800 28th Aug 2018 1:53pm
HK07
Thanks for the speedy response.
Sorry but that does not mean anything to me. 2007 90 Puma - Love it - Best car I have ever owned.
Post #725801 28th Aug 2018 1:57pm
Martin
Site Admin
The top terminal/stud with the "W" next to it is for a rev counter.
The battery light is connected to the smaller wire on the bottom set of three spades (two of which are wrapped in white tape).
The red spade with the (hopefully) BROWN with YELLOW wire is the battery warning light feed.
Your wiring has definitely been mucked about with - the proper alternator plug is missing. The two white-wrapped spades and the warning light spade should be in a proper plug: https://polevolt.co.uk/acatalog/Lucas-Alte...tml#SID=53  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #725803 28th Aug 2018 2:05pm
dorsetsmith
HK07 sorry on the mobile phone start with Embarassed have up dated post hop it make sense now
Post #725806 28th Aug 2018 2:32pm
HK07
Thanks guys, so the dangling wire is probably from when the alternator came from a different vehicle that had a revcounter.
Why is my battery light on permanently? If it wasn't on at all I would say a connection fault but with it on permanently I really am confused.
Much obliged for all the advice.
HK07 2007 90 Puma - Love it - Best car I have ever owned.
Post #726289 30th Aug 2018 5:02pm
dorsetsmith
you my have problem with your alternator regulator or brushes
Post #726292 30th Aug 2018 5:13pm
HK07
Thanks dorsetsmith. Thumbs Up
That's explains the system very well, now we have to find out why it's not working. 2007 90 Puma - Love it - Best car I have ever owned.
Post #726293 30th Aug 2018 5:29pm
HK07
Don't I feel silly!!!
Took her on a bit of a drive today, and when the revs rise a little the light goes out.
Thanks anyway guys Thumbs Up Thumbs Up Thumbs Up 2007 90 Puma - Love it - Best car I have ever owned.
Post #726533 31st Aug 2018 9:16pm
Martin
Site Admin
It's not had an LED bulb fitted in that position by any chance?  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #726545 31st Aug 2018 9:55pm
HK07
Don't think so - I'll check.it though. 2007 90 Puma - Love it - Best car I have ever owned.
Post #726548 31st Aug 2018 9:59pm
Martin
Site Admin
OK I just wonder if the alternator is not being excited correctly on the D+ (warning light) wire and so it's taking more revs to get it to kick in and start charging.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #726549 31st Aug 2018 10:00pm
