Home > My Defender > Proctas Defender 300TDI
Page 30 of 54 <123 ... 293031 ... 525354>
Procta
cheers pal, defenders are all new too me, I am hoping to make it more lux, we are a light years away from that I can tell you Laughing but we are moving on, come a long way since December 16 has it not, may not look it but its the little things.
Now I am starting to really get into the main stuff Thumbs Up Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
In the words of my Good Friend, Gary Forrest 1980 -2025
" we will work something out"
Post #675967 5th Jan 2018 2:40am
Procta
ok lads a little upgrade, I bought a set of our graftys little upgrade. He even threw in a Chinese menu too, just to spice the grade up Very Happy
Anyway while I was on my lunch hour, Me and a my mate. Decided to tackle a side each.
Great little upgrade Thumbs Up Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #677971 12th Jan 2018 7:40pm
Mash
Guernsey 1998 Defender 90 300 Tdi HT Nato Green
Looking good Thumbs Up 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
90 V8 - Maggie http://www.defender2.net/forum/topic42564.html
110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html
52HG25 lightweight https://www.defender2.net/forum/topic72342.html
D3 Hse - Fiona
Capri 2l S - Anna
Think I might have a problem............
Post #677983 12th Jan 2018 8:20pm
Procta
they are really a good upgrade, also I have the demister upgrade too, that you screw on. So its got quite a beefed up heater system now Very Happy
Also tomorrow, depending on the weather. We may start the brakes Very Happy I have had the parts in for months! Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #677991 12th Jan 2018 8:33pm
Mash
Brakes are always fun, if you are doing disks have you got new calliper bolts? Our official manual states new ones should be fitted every time the callipers are removed. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
D3 Hse - Fiona
Capri 2l S - Anna
Post #677992 12th Jan 2018 8:40pm
Procta
Ah Censored !! no I haven't. I have never ever had to replace them, even my dad didn't on his either.
But we will see what fun and games we will encounter, as I cannot see things going playing sailing. Looking at the rear bleed nipples! Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #677995 12th Jan 2018 8:45pm
grafty99
You can re use them if you wire brush them and loctite them. That's what I do with mine anyway and I haven't had a caliper fall off yet Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #678006 12th Jan 2018 9:17pm
Procta
we normally do that grafty tbh, only car I have had to replace bolts was the Rover metro. I fitted stainless steel ones, that was only due to one been odd sized and the others had well iffy heads.
I will take a photo of the toys I have to fit, at some point. But its going to be a mega upgrade, of the year I think this is. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #678013 12th Jan 2018 9:51pm
Mash
Agreed on cleaning at loctiting Thumbs Up not sure why we are told to replace, probably because some people aren’t that clever when it comes to doing their job.
Interestingly our manual says along the lines of if no new bolts are available replace bolts with loctite and then replace with new as soon as possible Confused 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
D3 Hse - Fiona
Capri 2l S - Anna
Post #678017 12th Jan 2018 9:56pm
Procta
All depends on how people remove them, Some people don't bother spraying down etc, so they end up making a hash of the job. My dad is well known for that, Working and working on with something till its Censored sadly. Hopefully it will not happen tomorrow, other wise its world war 3! He already knackered a nut on the 306 instead of leaving it, for a friend to have a look at it, He had better tools and may have even welded the nut back onto the frame. But my dad caused that much bother, we ended up having to cut the bolt etc. Evil or Very Mad Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #678021 12th Jan 2018 10:14pm
Procta
anyway grafty what is the story about this Chinese menu that you sent with the vents? Whistle Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #678024 12th Jan 2018 10:16pm
Mash
It’s his other side line business hopping to sting you on delivery Rolling with laughter Rolling with laughter 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
D3 Hse - Fiona
Capri 2l S - Anna
Post #678033 12th Jan 2018 10:49pm
Procta
well have a look at all the toys Very Happy
We began the strip down, and to see what nightmares were going to hit us.
We had a bit of a drama with the bolts for the brake calipar, took two of us to slacken those off, Then the flexi hose had to be cut off Rolling Eyes So we lost a fare bit of time there.
Once off
Stripped
New parts starting to go back on, My dad was sorting out the bearings, He made an error as normal Rolling Eyes
But soon we were rocking away
New disc ready do go on,
old unit,
These have seen better days have they not, and the one of the pads was more worn than the other. So there is a fault somewhere.
All installed, ready for the new uprated flange, ( we have to go back and fit the circlip As i have just discovered that you have to fit that back on. Going to be a bit of a struggle getting the shaft out for that i think Shocked )
New flange on, and all sorted
Also a little treat for you too, Whistle
we tried a new wheel on, just to see if the flanges would cause any dramas, Which they didnt and they fit better than the Censored have on now!
Only gripe i have, is i bought some land rover centre caps, and they do not Censored fit Evil or Very Mad Any ideas what caps fit these?
So tomorrow its round two with other side, and we may, just may have a look at the rears.
Smile Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #678199 13th Jan 2018 6:46pm
Procta
Only drama I had was our work light blowing up on me, Yes I was very lucky! Small fragments of bulb just missed me on that, My dad recons some brake fluid hit the bulb. Shocked Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #678200 13th Jan 2018 6:48pm
grafty99
The Chinese menu is nothing to do with me! It's not our local one Rolling with laughter 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #678204 13th Jan 2018 7:09pm
