![]() | Home > My Defender > Proctas Defender 300TDI |
| Procta Member Since: 03 Dec 2016 Location: Sunderland Posts: 5376
ok lads a little upgrade, I bought a set of our graftys little upgrade. He even threw in a Chinese menu too, just to spice the grade up
Click image to enlarge Anyway while I was on my lunch hour, Me and a my mate. Decided to tackle a side each. Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Great little upgrade In the words of my Good Friend, Gary Forrest 1980 -2025 " we will work something out" Last edited by Procta on 12th Jan 2018 7:30pm. Edited 1 time in total |
| Mash Member Since: 09 Feb 2015 Location: Guernsey Posts: 1674
Looking good
they are really a good upgrade, also I have the demister upgrade too, that you screw on. So its got quite a beefed up heater system now
Also tomorrow, depending on the weather. We may start the brakes In the words of my Good Friend, Gary Forrest 1980 -2025 " we will work something out" |
Brakes are always fun, if you are doing disks have you got new calliper bolts? Our official manual states new ones should be fitted every time the callipers are removed. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
Ah
But we will see what fun and games we will encounter, as I cannot see things going playing sailing. Looking at the rear bleed nipples! Defender TD5 90 ---/--- Peugeot 306 HDI hatch back In the words of my Good Friend, Gary Forrest 1980 -2025 " we will work something out" |
| grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4803
You can re use them if you wire brush them and loctite them. That's what I do with mine anyway and I haven't had a caliper fall off yet
we normally do that grafty tbh, only car I have had to replace bolts was the Rover metro. I fitted stainless steel ones, that was only due to one been odd sized and the others had well iffy heads.
I will take a photo of the toys I have to fit, at some point. But its going to be a mega upgrade, of the year I think this is. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back In the words of my Good Friend, Gary Forrest 1980 -2025 " we will work something out" |
Agreed on cleaning at loctiting
Interestingly our manual says along the lines of if no new bolts are available replace bolts with loctite and then replace with new as soon as possible 90 V8 - Maggie http://www.defender2.net/forum/topic42564.html 110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html 52HG25 lightweight https://www.defender2.net/forum/topic72342.html D3 Hse - Fiona Capri 2l S - Anna Think I might have a problem............ |
All depends on how people remove them, Some people don't bother spraying down etc, so they end up making a hash of the job. My dad is well known for that, Working and working on with something till its
anyway grafty what is the story about this Chinese menu that you sent with the vents?
It’s his other side line business hopping to sting you on delivery
well have a look at all the toys
Click image to enlarge Click image to enlarge Click image to enlarge We began the strip down, and to see what nightmares were going to hit us. Click image to enlarge Click image to enlarge We had a bit of a drama with the bolts for the brake calipar, took two of us to slacken those off, Then the flexi hose had to be cut off Once off Click image to enlarge Click image to enlarge Stripped Click image to enlarge Click image to enlarge New parts starting to go back on, My dad was sorting out the bearings, He made an error as normal But soon we were rocking away New disc ready do go on, Click image to enlarge old unit, These have seen better days have they not, and the one of the pads was more worn than the other. So there is a fault somewhere. All installed, ready for the new uprated flange, ( we have to go back and fit the circlip As i have just discovered that you have to fit that back on. Going to be a bit of a struggle getting the shaft out for that i think Click image to enlarge New flange on, and all sorted Click image to enlarge Also a little treat for you too, we tried a new wheel on, just to see if the flanges would cause any dramas, Which they didnt and they fit better than the Click image to enlarge Only gripe i have, is i bought some land rover centre caps, and they do not So tomorrow its round two with other side, and we may, just may have a look at the rears. In the words of my Good Friend, Gary Forrest 1980 -2025 " we will work something out" |
Only drama I had was our work light blowing up on me, Yes I was very lucky! Small fragments of bulb just missed me on that, My dad recons some brake fluid hit the bulb.
The Chinese menu is nothing to do with me! It's not our local one
| All times are GMT |
