![]() | Home > Maintenance & Modifications > Aircon Stainless Lower Grill? |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7946 ![]() ![]() ![]() |
Mine came out a treat no problems using just a bulk standard metal drill I had.
![]() MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
X4CAC Member Since: 30 Apr 2018 Location: Midlands Posts: 212 ![]() ![]() ![]() |
Same here, nothing fancy just a standard domestic drill
strang Member Since: 16 May 2012 Location: Happy Valley Posts: 1403 ![]() ![]() ![]() |
Which way are you drilling them from? I did mine from the front so just drilling into soft aluminium of the rivet head - I guess if you are drilling from the back, and the snap off steel centre is still in the rivet then that will be harder. Euro-Leafing to infinity and beyond.....
Stacey007 Member Since: 25 Sep 2015 Location: Cheshire Posts: 3891 ![]() ![]() |
I did mine yesterday,
Drill from the front you just end up with a collection of 'washer' type bits on your drill ![]() Looks much better now. |
Brendlynch Member Since: 06 Nov 2016 Location: Grouville Posts: 182 ![]() ![]() ![]() |
Yep was drilling from the front. Suspect my drill bits aren’t the right size. What size did you use?
Intercept Member Since: 27 Feb 2017 Location: Suffolk Posts: 587 ![]() ![]() ![]() |
5mm is ideal |
