Home > Maintenance & Modifications > Aircon Stainless Lower Grill?
Page 1 of 3 123>
Yannis
United Kingdom 2015 Defender 90 Puma 2.2 CSW Corris Grey
Ciao,
The lower mesh on my grill has started to flake after 18months as did the windscreen hinges. I know it's something I could have replaced under warrenty but as I plan on keeping the vehicle I would rather replace the poor quality Land Rover part with something nice that's going to last.
Has anyone found an anodised aluminium grill? or has anyone sourced a good quality stainless grill?
This was the state of the windscreen hinge;
It has now been replaced with a nice Croytec set which are a million times better and which also stopped a slight leak on the corner of the windscreen seal.
Yan
Post #546741 7th Jul 2016 7:21am
MartinK
Yannis
I saw one (in Stainless) at the Scottish Land Rover Show.. a TMD one:
http://tmdtuning.com/shop/ssteel-lower-grille/
Is that what you need?
As I don't have aircon...I don't need one Cool Thumbs Up Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #546748 7th Jul 2016 7:46am
leeds
Hi Yannis, have a look at the Nakatanenga stainless air con grill on 4x4 Overlander.com
Available in naked stainless for painting or black powder coated stainless.
Unlike others available it has the correct shape and size of holes in it so looks original.
Brendan
Post #546752 7th Jul 2016 8:20am
MartinK
Brendan - they're lovely Smile
http://www.4x4overlander.com/product/defen...stainless/
The NAKA products are always good Thumbs Up Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #546798 7th Jul 2016 11:27am
Mwd
I fitted the Nakatenenga grille from 4x4overlander to mine (naked stainless steel version). It came with pop rivets but I used stainless torx machine screws with nyloc nuts because I was paranoid that the rivets would crack the plastic surround. By far the slowest part of the job was removing the rivets holding the old grille. I cut them off from behind using a Dremel-type cutting disc - drilling them might have been quicker, but I was worried about damaging the plastic surround. The new S/S grille rusted straight away, but I wonder if this could be residue from the manufacturing process, and not the grille itself
rusting. I haven't tried cleaning it yet, but it doesn't look as good as I hoped stainless steel would. I agree that anodised aluminium would be great but I didn't manage to find one.
Post #546899 7th Jul 2016 5:57pm
Martin
Site Admin
I would say take that up with Nak/4x4overlander as I would not expect a premium stainless grille to corrode like that.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #546901 7th Jul 2016 6:00pm
JOW240725
I've just fitted the TMD stainless lower grille. Fitted great, stainless rivets supplied were great but way bigger than they needed to be. Pleased with the result, much better then the badly corroded original. James
Instagram @suffolk_rovers
Post #546910 7th Jul 2016 6:37pm
durham
England 2014 Defender 110 Puma 2.2 USW Corris Grey
Thats doesnt look impressive!
There was a grille being offered by tmdtuning.com, which got good feedback. Apparently best to stainless steel nut and bolt it on, as rivets also lead to a metals reaction problem. Discount code "angrypuma2016" gets a little off.
Mine was done under warranty, rivets touched up by hand etc. Windscreen blocks/hinges done at the same time
Post #546911 7th Jul 2016 6:39pm
leeds
MWD, please email me at brendan@4x4overlander,com with your name and address, phone number etc so we can resolve this matter. An invoice number would be useful but not essential.
I will direct Peter at Nakatanenga to this thread for his input.
IF ANYONE has an issue with an item we have supplied please let us know. Just send us an email with photos if possible, plus name/address/when bought etc and we will do our best to resolve the issue.
If we do not know about the issue we simply can not try and resolve the issue.
Brendan
Post #546925 7th Jul 2016 8:04pm
dorsetsmith
Post #546933 7th Jul 2016 8:29pm
JOW240725
Britpart stainless steel lower grille from TMD
 James
Post #546950 7th Jul 2016 9:26pm
mcma1
I took the black Nakat one from Brendan, and fitted it before painting, love it
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Andy
2014 Fuji 110 SW LS3
https://www.defender2.net/forum/post751233.html#751233
2014 Corris 110 SW
http://www.defender2.net/forum/topic40056.html
My old Xtech 90 build..
http://www.defender2.net/forum/topic15681.html
LS3 V8 build...
http://www.defender2.net/forum/topic49051.html
Post #546960 7th Jul 2016 9:53pm
JOW240725
Trumped Rolling with laughter Bow down Thumbs Up
We ought to produce a Def2 top trumps! James
Post #546963 7th Jul 2016 9:58pm
K9F
No rust on the ones I used to knock out before others jumped on the bandwagon. Rolling with laughter
http://www.defender2.net/forum/topic8534.h...ler+grille If you go through life with your head in the sand....all people will see is an ar5e!!
Post #546976 7th Jul 2016 10:44pm
nakatanenga
Germany
Looks strange!
The quality is 1.4301 Stainless. We never had problems like this. Brendan will change it FOC
As it is on the laser cut edges it might be something from the manufacturing process. We will return the unit to the laser cutter for inspection. WANTED:
SII or SIII in max 1.5k
Post #547024 8th Jul 2016 8:08am
Page 1 of 3 123>
