Home > Maintenance & Modifications > Aircon Stainless Lower Grill?
Page 3 of 3 <123
JOW240725
Mine came out a treat no problems using just a bulk standard metal drill I had. Confused James
Instagram @suffolk_rovers
Post #775300 28th May 2019 3:01pm
X4CAC
United Kingdom 2014 Defender 90 Puma 2.2 XS CSW Corris Grey
Same here, nothing fancy just a standard domestic drill
Post #775303 28th May 2019 4:00pm
Brendlynch
Jersey 2005 Defender 110 Td5 XS CSW Cairns Blue
I see to be going through more drill bits than pop rivets I’m removing Big Cry
Post #775307 28th May 2019 4:13pm
strang
United Kingdom 2009 Defender 90 Puma 2.4 XS CSW Galway Green
Which way are you drilling them from? I did mine from the front so just drilling into soft aluminium of the rivet head - I guess if you are drilling from the back, and the snap off steel centre is still in the rivet then that will be harder. Euro-Leafing to infinity and beyond.....
Post #775447 29th May 2019 6:22pm
Stacey007
I did mine yesterday,
Drill from the front you just end up with a collection of 'washer' type bits on your drill Smile they came out easy.
Looks much better now.
Post #775448 29th May 2019 6:42pm
Brendlynch
Yep was drilling from the front. Suspect my drill bits aren’t the right size. What size did you use?
Post #775562 30th May 2019 2:54pm
Intercept
United Kingdom 2002 Defender 110 Td5 Black LE Java Black
5mm is ideal
Post #775569 30th May 2019 3:56pm
Page 3 of 3 <123
