Home > Maintenance & Modifications > Safari Equipment R & T Sliders.
Page 1 of 4 1234>
K9F
Picture heavy. Excuse quality of pictures.
I took advantage of Santa Brendan's offer (before he got grumpy again) and purchased a set of these over Christmas. Suffering from mild OCD I requested specifically for "A totally unblemished set with extra packing please!" That is exactly what I got. Thank you Brendan. Finally got round to fitting the first one today, second is planned for Wednesday. As with everything Defender a little 'fettling' was required, due to the fact my wheel width is quite wide and I had moved the mud flaps outward with the Entreq brackets I also had to reprofile the top of the front mud flap to accommodate the slider. Nevertheless as with everything with the Safari Equipment brand the quality is excellent, galvanised and powder coated. Thanks to Brendan for answering my queries today on the phone. Still got the three nuts left over.
Laughing Thumbs Up
Standard XS sidestep and sill to be removed. Got a mat out of the garage so I wouldn't get 'Farmer Giles' in the cold.
Sidestep and sill removed.
Fitted.
 If you go through life with your head in the sand....all people will see is an ar5e!!
Post #390263 19th Jan 2015 6:44pm
captain slow
United Kingdom 2014 Defender 110 Puma 2.2 CSW Corris Grey
nice Job! Thumbs Up
can't decide whether to swap my bowler sills for R&T sliders, but you have made me think... 2.2 Tdci 110 XS CSW Corris Grey
Prince Harry's D3 (gone but not forgotten)
300 Tdi 110 CSW (gone but not forgotten)
Post #390270 19th Jan 2015 6:59pm
MartinK
Looks excellent - I would follow your example in a minute if MrsK would agree - she's only 5' 2" and was the instigator of me fitting the same side steps as you've taken off! Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #390272 19th Jan 2015 7:06pm
TooTall
United Kingdom 2004 Defender 90 Td5 HT Tonga Green
Can I just add that since fitting my R&T sliders, my truck seems far quieter to drive... in that it seems to creak & groan less Rolling Eyes
TT
 "Ease your worries, Clear-up your woes,
Go into your garage & put stuff into rows."
Post #390326 19th Jan 2015 8:36pm
leeds
Oi K9F I am allowed to be GRUMPY now you know Thumbs Up
Glad they turned up OK with no damage. We do try to listen to people you know! Razz
How did you describe yourself now?
You will find them useful in supermarket carparks you know.
Brendan
Post #390411 19th Jan 2015 10:55pm
K9F
Laughing Hi Brendan, your words not mine. I didn't notice any hint of grumpiness when we spoke today!
leeds wrote:
............as the last of the Christmas spirit is fast draining away. Then I can return to being my normal grumpy git....Brendan
'Anally retentative with attention to detail' when it comes to fitting kit to my Defender today I would describe myself. Thanks again.
Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #390419 19th Jan 2015 11:07pm
deplec
United Kingdom 2011 Defender 90 Puma 2.4 X-Tech LE Zambezi Silver
They look excellent. May need to consider that myself.
Post #390422 19th Jan 2015 11:13pm
landy andy
Very good bits of kit. Had them on my 90, and now a new set on the 110.
I use them a lot to get stuff on and off the roof rack, and they are very slippery when wet, so I stick 1" skate board tape along the tops. It stops you falling off them, but as is on the top only, you don't ladder your tights getting out Whistle
Andy
Post #390437 20th Jan 2015 12:27am
K9F
Good tip, I'm going to have a root round today to see if I can lay my hands on some anti-slip patches myself. Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #390466 20th Jan 2015 8:26am
landy andy
Post #390471 20th Jan 2015 8:52am
Anderzander
Excuse the ignorant question ... But how flush can you get a rock slider to sit ?
Can it sit in line with where the original sill did ? Or will always protrude beyond that ?
Post #390472 20th Jan 2015 9:43am
leeds
We've got a couple of http://www.4x4overlander.com/product/maxig...-curved-2/ on to cope with the slippiness -perfect for getting in and out of the driver's door but not in quite the right place for the passenger door as somebody never asked where I put my feet and hasn't had time to move them. We used to have grippa tape on and these are much kinder to your tights and don't get clogged up with muck.
Regards
Barbara
Post #390473 20th Jan 2015 9:47am
landy andy
You can get them more flush, not completely flush, and they are called rock sliders. Rock and tree sliders have the extra bar for protection.
http://www.4x4overlander.com/product/rock-...ender-110/
http://www.extreme4x4.co.uk/acatalog/DEFENDER_ROCK_SLIDERS.html
http://www.bing.com/images/search?q=rock+s...edIndex=54
Andy
Post #390474 20th Jan 2015 9:48am
mk1collector
Can the rock sliders (without the extra bar) fit with side steps still fitted?
Post #390483 20th Jan 2015 10:30am
rallysteve
I also bought a pair of these from Brendan, excellent service of course.
They seem to fit nice and tight upto the bottom of the doors/pillars/wings and pull in tight to the inner sills on our double cab.
Only issue I have with fitting them is that you seem to get 4 shims with them, unforunately (possibly due to the usual build tolerances and the new YRM mid body x-member I fitted) seem to need one shim each side on the rear most mount and 2 or three on each side of the middle mounts!
Have got some strip steel to make up some more shims which should let me tuck them right up to the body.
Also got some interesting door seal ideas for the bottom of the doors/top of the sliders.
Post #390543 20th Jan 2015 3:09pm
Page 1 of 4 1234>
