![]() | Home > Maintenance & Modifications > Safari Equipment R & T Sliders. |
Picture heavy. Excuse quality of pictures.
I took advantage of Santa Brendan's offer (before he got grumpy again) and purchased a set of these over Christmas. Suffering from mild OCD I requested specifically for "A totally unblemished set with extra packing please!" That is exactly what I got. Thank you Brendan. Finally got round to fitting the first one today, second is planned for Wednesday. As with everything Defender a little 'fettling' was required, due to the fact my wheel width is quite wide and I had moved the mud flaps outward with the Entreq brackets I also had to reprofile the top of the front mud flap to accommodate the slider. Nevertheless as with everything with the Safari Equipment brand the quality is excellent, galvanised and powder coated. Thanks to Brendan for answering my queries today on the phone. Still got the three nuts left over. ![]() ![]() Standard XS sidestep and sill to be removed. Got a mat out of the garage so I wouldn't get 'Farmer Giles' in the cold. ![]() Click image to enlarge Sidestep and sill removed. ![]() Click image to enlarge Fitted. ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
MartinK Member Since: 02 Mar 2011 Location: Clackmannanshire Posts: 2676 ![]() ![]() ![]() |
Looks excellent - I would follow your example in a minute if MrsK would agree - she's only 5' 2" and was the instigator of me fitting the same side steps as you've taken off! Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
TooTall Member Since: 10 Jul 2012 Location: Fens Posts: 504 ![]() ![]() ![]() |
Can I just add that since fitting my R&T sliders, my truck seems far quieter to drive... in that it seems to creak & groan less
![]() TT ![]() Click image to enlarge "Ease your worries, Clear-up your woes, Go into your garage & put stuff into rows." |
Oi K9F I am allowed to be GRUMPY now you know
![]() Glad they turned up OK with no damage. We do try to listen to people you know! ![]() How did you describe yourself now? You will find them useful in supermarket carparks you know. Brendan |
'Anally retentative with attention to detail' when it comes to fitting kit to my Defender today I would describe myself. Thanks again. ![]() Treat every day as if it is your last....one day you will be right!! |
deplec Member Since: 21 Aug 2012 Location: Yorkshire Posts: 152 ![]() ![]() ![]() |
They look excellent. May need to consider that myself.
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5991 ![]() ![]() |
Very good bits of kit. Had them on my 90, and now a new set on the 110.
I use them a lot to get stuff on and off the roof rack, and they are very slippery when wet, so I stick 1" skate board tape along the tops. It stops you falling off them, but as is on the top only, you don't ladder your tights getting out ![]() Andy |
Good tip, I'm going to have a root round today to see if I can lay my hands on some anti-slip patches myself.
This is what I use
http://www.ebay.co.uk/itm/25mm-x-1m-Black-...2c95391b2e Andy |
Anderzander Member Since: 08 Feb 2011 Location: Lancashire Posts: 1000 ![]() ![]() |
Excuse the ignorant question ... But how flush can you get a rock slider to sit ?
Can it sit in line with where the original sill did ? Or will always protrude beyond that ? |
We've got a couple of http://www.4x4overlander.com/product/maxig...-curved-2/ on to cope with the slippiness -perfect for getting in and out of the driver's door but not in quite the right place for the passenger door as somebody never asked where I put my feet and hasn't had time to move them. We used to have grippa tape on and these are much kinder to your tights and don't get clogged up with muck.
Regards Barbara |
You can get them more flush, not completely flush, and they are called rock sliders. Rock and tree sliders have the extra bar for protection.
http://www.4x4overlander.com/product/rock-...ender-110/ http://www.extreme4x4.co.uk/acatalog/DEFENDER_ROCK_SLIDERS.html http://www.bing.com/images/search?q=rock+s...edIndex=54 Andy |
Can the rock sliders (without the extra bar) fit with side steps still fitted?
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2242 ![]() ![]() ![]() |
I also bought a pair of these from Brendan, excellent service of course.
They seem to fit nice and tight upto the bottom of the doors/pillars/wings and pull in tight to the inner sills on our double cab. Only issue I have with fitting them is that you seem to get 4 shims with them, unforunately (possibly due to the usual build tolerances and the new YRM mid body x-member I fitted) seem to need one shim each side on the rear most mount and 2 or three on each side of the middle mounts! Have got some strip steel to make up some more shims which should let me tuck them right up to the body. Also got some interesting door seal ideas for the bottom of the doors/top of the sliders. Steve 02' 110 TD5 Double Cab Rebuild Thread |
