Home > Td5 > Leaking front and Rear windscreens |
charliebaja Member Since: 05 Aug 2013 Location: Surrey Posts: 211 |
Just driving out to lunch on Friday I noticed that i had air bubbles coming up on the inside of my windscreen at the bottom, they went on for 6 - 5 minutes, sadly letting in water then stopped. Also when washing the car today i saw that the rear screen around the very top was letting in water. With both these facts in mind, how easy is it to change the screen seals and is it much like the side windows as to how these are originally fitted?
26th Oct 2014 9:34pm |
Dirt and grime collecting under the front windscreen seal is well documented, sealing externally will not cure this but will if damp seal the dampness in and you may eventually see corrosion spots/bubbles leeching from under the edge of the seal. There is only one decent cure, windscreen out, clean the area thoroughly and using sealant to seal the windscreen seal thoroughly. Follow the links below or do a search for any more info you may need.
If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
27th Oct 2014 9:40am |
epictrail Member Since: 21 Sep 2013 Location: High Wycombe Posts: 395 |
I'd use this sealant under the rubber seal. Did mine last week and leak solved. Lift the edge of the rubber seal and squirt plenty in and wipe of excess.
Stays flexible so easy to clean off if the screen is changed later on as opposed to Tigerseal etc which is a nightmare to clean off. http://www.arbo.co.uk/arbo-sealants/arbomast-autograde/ http://www.ebay.co.uk/itm/like/25168115381...p;ff14=108 |
27th Oct 2014 10:32am |
