Home > Off Topic > how to best cut up waffle boarding
landyman40
United Kingdom 2003 Defender 110 Td5 XS CSW Zermatt Silver
Hi
I've just bought a large sheet of waffle boarding 2" thick. Any advice on how best to cut this up as not getting anywhere with a jig saw . Cut out one off road waffle board by hand and my arm has had enough any one got any ideas how to cut this stuff up more easily Thanks Banging Head defender Td5 110xs
Freelander 2 Td4e GS
Post #362676 6th Oct 2014 6:42pm
Grouse
Stihl saw AND dust mask
Post #362683 6th Oct 2014 7:11pm
grizz
2014 Defender 110 Puma 2.2 XS CSW Corris Grey
How about a reciprocating saw ... I have one at work and its great .
http://www.screwfix.com/c/tools/reciprocat...oC49jw_wcB
Post #362685 6th Oct 2014 7:20pm
X4SKP
Hi landyman40
Are they GRP Question if so a hand grinder with the right cutting disc.
A GRP Disc won't clog (as easily) you can also use a lubricant, washing up liquid will do Exclamation
A Hand Grinder gives a clean cut too Thumbs Up SKIP
Post #362687 6th Oct 2014 7:23pm
JWL
9" grinder with a thin cutting disc, and a mask plus goggles.
Post #362689 6th Oct 2014 7:24pm
shaggydog
If you were closer I'd say drop it in to my work and I'd run it through the waterjet for you.
Otherwise does anyone neer you have a big circular saw?
Post #362698 6th Oct 2014 7:38pm
sparkylee
2012 Defender 110 Puma 2.2 DCPU Santorini Black
Can you let me know where you got the sheet and also what colour it is
Cheers It's good to be back from the dark side
DC110 -2012 Black with black hood and black x-tech
FFRR 4.2 vogue
Renault traffic auto
PT crusier convertible
Laika x700 Motorhome
Post #362700 6th Oct 2014 7:48pm
alwoodley72
England 2008 Defender 130 Puma 2.4 HCPU Alaska White
I would have thought that a saw blade rather than a disc would be better, the grinders will ' melt' the cut- a circular skil saw would be best running along a clamped straight edge..
Cheers. Alex
Post #362744 6th Oct 2014 10:05pm
uncas
I used a jig saw when I cut some to size a few years ago it was hard going.
Uncas
Post #362768 6th Oct 2014 11:20pm
Mountain_man
Wales
I had a pallet full of the stuff in various sizes to make waffle boards out of. I simply sued a 9" grinder with a diamond disc or a Stainless disc in. Done in seconds. Wear appropriate PPE as it is a dusty old job
Post #362769 6th Oct 2014 11:44pm
