![]() | Home > Off Topic > how to best cut up waffle boarding |
Grouse Member Since: 16 Apr 2012 Location: on the hill Posts: 536 ![]() |
Stihl saw AND dust mask
grizz Member Since: 31 Aug 2014 Location: cheshire Posts: 208 ![]() ![]() |
How about a reciprocating saw ... I have one at work and its great .
http://www.screwfix.com/c/tools/reciprocat...oC49jw_wcB |
X4SKP Member Since: 29 Nov 2013 Location: Berkshire Posts: 2304 ![]() ![]() ![]() |
Hi landyman40
Are they GRP ![]() A GRP Disc won't clog (as easily) you can also use a lubricant, washing up liquid will do ![]() A Hand Grinder gives a clean cut too ![]() https://www.defender2.net/forum/topic83242.html |
9" grinder with a thin cutting disc, and a mask plus goggles.
shaggydog Member Since: 12 Aug 2012 Location: Kent Posts: 3347 ![]() ![]() ![]() |
If you were closer I'd say drop it in to my work and I'd run it through the waterjet for you.
Otherwise does anyone neer you have a big circular saw? |
sparkylee Member Since: 06 Nov 2010 Location: surrey Posts: 1455 ![]() ![]() |
Can you let me know where you got the sheet and also what colour it is
Cheers It's good to be back from the dark side DC110 -2012 Black with black hood and black x-tech FFRR 4.2 vogue Renault traffic auto PT crusier convertible Laika x700 Motorhome |
alwoodley72 Member Since: 14 Mar 2010 Location: salisbury, wilts Posts: 729 ![]() ![]() ![]() |
I would have thought that a saw blade rather than a disc would be better, the grinders will ' melt' the cut- a circular skil saw would be best running along a clamped straight edge..
Cheers. Alex |
uncas Member Since: 22 Nov 2012 Location: Wentworth near Rotherham Posts: 340 ![]() ![]() |
I used a jig saw when I cut some to size a few years ago it was hard going.
Uncas |
Mountain_man Member Since: 09 Dec 2011 Location: Right side of Offas Dyke Posts: 756 ![]() ![]() |
I had a pallet full of the stuff in various sizes to make waffle boards out of. I simply sued a 9" grinder with a diamond disc or a Stainless disc in. Done in seconds. Wear appropriate PPE as it is a dusty old job
