Home > Maintenance & Modifications > Warn Winch Kit: VPLDP0113
Martyn
United Kingdom 2014 Defender 90 Puma 2.2 PU Keswick Green
Has anyone had the above kit fitted to a new Defender recently?
Microcat isn't good at listing what comes in the kit.
Can anyone tell me, does the kit include a centre console mounted cut out switch and Warn winch cover for the 9.5ti unit?
Thanks.
Post #308613 16th Feb 2014 4:43pm
Might not help as it's a different partnumber but list of included items for a winch fitting kit are here:
http://topix.landrover.jlrext.com/topix/co...tabs=false
Post #308671 16th Feb 2014 7:11pm
Martyn
Yerrr I already had a nosey on Topix ta. The current Winch kit is not listed and by the looks of the instructions, that's a very old part.
Post #308676 16th Feb 2014 7:26pm
a13x
My 2011 had the cut off switch fitted. Believe the cover is an additional cost. I have one but virtually impossible to fit! (I do have svx grill which may make a difference)
Post #308700 16th Feb 2014 8:34pm
Greener78
2015 Defender 110 Puma 2.2 XS CSW Montalcino Red
Had it fitted to my 13 plate back in July. Switch and cover both supplied. Haven't used the cover yet tho.
Think you might have to remove the numberplate and refit, simple pin to pull out.
Post #308818 17th Feb 2014 10:57am
Martyn
Thanks for that greener.
Funny you mention about the number plate pin. Dealer have asked if I want the number plate mounted centrally or to the left on the bumper. At the time, I was unsure how the cover if any would fit with the plate in the centre.
Did they have to cut your grille unit to accommodate the main winch unit?
Post #308925 17th Feb 2014 7:11pm
kingofthesparks
Location: Very close to Watford gap services , northants
United Kingdom 2012 Defender 90 Puma 2.2 HT Fuji White
No grill cut required though instructions say it is required Confused
Post #308937 17th Feb 2014 8:11pm
landy andy
Agree with above. Instructions say cut but not needed.
Andy
Post #308952 17th Feb 2014 9:26pm
