![]() | Home > Maintenance & Modifications > Warn Winch Kit: VPLDP0113 |
Might not help as it's a different partnumber but list of included items for a winch fitting kit are here:
http://topix.landrover.jlrext.com/topix/co...tabs=false |
Martyn Member Since: 10 Feb 2011 Location: Stourbridge, West Midlands Posts: 151 ![]() ![]() ![]() |
Yerrr I already had a nosey on Topix ta. The current Winch kit is not listed and by the looks of the instructions, that's a very old part.
a13x Member Since: 25 Sep 2011 Location: Burton on Trent Posts: 555 ![]() ![]() |
My 2011 had the cut off switch fitted. Believe the cover is an additional cost. I have one but virtually impossible to fit! (I do have svx grill which may make a difference)
Greener78 Member Since: 18 Apr 2013 Location: Keswick Posts: 48 ![]() ![]() |
Had it fitted to my 13 plate back in July. Switch and cover both supplied. Haven't used the cover yet tho.
Think you might have to remove the numberplate and refit, simple pin to pull out. |
Thanks for that greener.
Funny you mention about the number plate pin. Dealer have asked if I want the number plate mounted centrally or to the left on the bumper. At the time, I was unsure how the cover if any would fit with the plate in the centre. Did they have to cut your grille unit to accommodate the main winch unit? |
kingofthesparks Member Since: 06 Jan 2011 Location: Very close to Watford gap services , northants Posts: 987 ![]() ![]() ![]() |
No grill cut required though instructions say it is required
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5986 ![]() ![]() |
Agree with above. Instructions say cut but not needed.
Andy |
