Home > Technical > Rear door lock problems |
Blacktt600 Member Since: 30 Nov 2013 Location: Leeds Posts: 125 |
As of today I have the same problem, it opens with the key though.Will have a look this weekend when I get chance.
15th Jan 2014 7:05pm |
Romadog Member Since: 07 Jul 2011 Location: Powys Posts: 1746 |
This is a common problem apparently. I think it comes from too much end float on the white plastic pivot between the metal rod from the solenoid and the lock itself. I thought I'd fixed this by putting a bend in the rod from the lock. Immediately it was better, but it seemed to play up with me again at the weekend.
15th Jan 2014 7:12pm |
Just sprayed wd40 in the slot where the black lever is and it's now working fine.😀
15th Jan 2014 7:31pm |
EWS Member Since: 29 Nov 2011 Location: Bristol Posts: 156 |
I had similar problem, found the white plastic jobbie was working its way out of the hole, so screwed in a chunky self tapping screw through the center of white jobbie to spread the retaining lugs. two years and no further problems with it. |
15th Jan 2014 7:39pm |
Harald Member Since: 30 May 2012 Location: Flanders Fields Posts: 81 |
THNX, this weekend I will have a closer look at it and see if I can find (and fix) anything.
I'll keep you informed, Harald |
16th Jan 2014 8:50am |
A picture I found on the WWW:
Click image to enlarge |
16th Jan 2014 8:51am |
Thorougly cleaning and afterwards some Innotec Hogh-tef oil did the trick.
Thanks to all, Harald |
17th Feb 2014 2:31pm |
