Home > Technical > Rear door lock problems
Harald
Belgium 2010 Defender 90 Puma 2.4 Fire LE Vesuvius Orange
When I close my LR defender Puma (2010) with the remote controle everything closes.
But when I open it with the remote controle I can't open the backdoor.
Inside on the lock you see the little black .... goes up when closing, but comes only half down when opening.
Anyone has the same problem, and maybe knows a solution to fix this?
Post #299114 15th Jan 2014 6:54pm
Blacktt600
England 2008 Defender 110 Puma 2.4 XS CSW Cairns Blue
As of today I have the same problem, it opens with the key though.Will have a look this weekend when I get chance.
Post #299119 15th Jan 2014 7:05pm
Romadog
This is a common problem apparently. I think it comes from too much end float on the white plastic pivot between the metal rod from the solenoid and the lock itself. I thought I'd fixed this by putting a bend in the rod from the lock. Immediately it was better, but it seemed to play up with me again at the weekend. Evil or Very Mad
Post #299121 15th Jan 2014 7:12pm
Blacktt600
Just sprayed wd40 in the slot where the black lever is and it's now working fine.😀
Post #299131 15th Jan 2014 7:31pm
EWS
United Kingdom 2006 Defender 90 Td5 HT Alveston Red
I had similar problem, found the white plastic jobbie was working its way out of the hole, so screwed in a chunky self tapping screw through the center of white jobbie to spread the retaining lugs. two years and no further problems with it.
Post #299132 15th Jan 2014 7:39pm
Harald
THNX, this weekend I will have a closer look at it and see if I can find (and fix) anything.
I'll keep you informed, Harald
Post #299270 16th Jan 2014 8:50am
Harald
A picture I found on the WWW:
Post #299271 16th Jan 2014 8:51am
Harald
Thorougly cleaning and afterwards some Innotec Hogh-tef oil did the trick.
Thanks to all,
Harald
Post #308850 17th Feb 2014 2:31pm
