![]() | Home > Technical > Rear door lock problems |
| Blacktt600 Member Since: 30 Nov 2013 Location: Leeds Posts: 125
As of today I have the same problem, it opens with the key though.Will have a look this weekend when I get chance.
| Romadog Member Since: 07 Jul 2011 Location: Powys Posts: 1751 |
This is a common problem apparently. I think it comes from too much end float on the white plastic pivot between the metal rod from the solenoid and the lock itself. I thought I'd fixed this by putting a bend in the rod from the lock. Immediately it was better, but it seemed to play up with me again at the weekend.
Just sprayed wd40 in the slot where the black lever is and it's now working fine.😀
| EWS Member Since: 29 Nov 2011 Location: Bristol Posts: 156
I had similar problem, found the white plastic jobbie was working its way out of the hole, so screwed in a chunky self tapping screw through the center of white jobbie to spread the retaining lugs. two years and no further problems with it. |
| Harald Member Since: 30 May 2012 Location: Flanders Fields Posts: 81
THNX, this weekend I will have a closer look at it and see if I can find (and fix) anything.
I'll keep you informed, Harald |
A picture I found on the WWW:
Click image to enlarge |
Thorougly cleaning and afterwards some Innotec Hogh-tef oil did the trick.
Thanks to all, Harald |
| All times are GMT |
