![]() | Home > General & Technical (L663) > GAP Diagnostic IIDTool Announcement |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 3243 ![]() ![]() |
Okay thank you l will call Duckworth today and see if l can get one ordered.
stevemfr Member Since: 18 Sep 2022 Location: Strasbpurg Posts: 157 ![]() ![]() |
It is still "coming soon" for the general public as we have not yet released the software to the public in general. But as Patrick said in the first post in this thread, we are accepting beta testers for a pre-release software version. As for the versions of the IIDTool: there is the IIDTool BT designed for the individual (end user) and the IIDTool Pro, obviously designed for the... Pro user. Only the Pro has a subscription fee as our interaction with technicians using the IIDTool in a repair shop is much more intense and regular, not only in support of solving problems on the vehicles but also for software updates on vehicle ECUs, etc. Functionality included in the BT is the same as in the Pro. An IIDTool BT has a VIN lock on advanced functions such as CCF editing and programming whereas basic functions are free of a lock. As what we classify as basic functions is basically equivalent to all functions available on a Lynx or Hawkeye or similar, a regular IIDTool BT is on the same level as the Pro versions of these tools. Obviously a Pro is completely VIN lock free. HTH ![]() RRC 2Dr, RRC 4Dr, P38, and 2 L322s, 2 FL1s and a L663 on the way |
Thank you for the recommendation. However l was already in touch with Duckworth. l left a message and received a call the next day from Sophie. She was very helpful and l've ordered the unit at around £430 |
northeye Member Since: 18 Sep 2022 Location: Tokyo Posts: 19 ![]() ![]() |
Hi guys.
I've found some posts about to enable the 'WalkAwayLocking' but could not find about the 'Approach Unlocking' on this topic. I tried to enable 'Approach Unlocking' and succeeded. My vehicle is MY23.5 without fuel tank flap locking. MultiCAN-807 Approach Unlocking from: Disabled to: Enabled So could you please add this to the list? Regards. |
forzahog Member Since: 03 Nov 2022 Location: Fayetteville Posts: 67 ![]() ![]() ![]() |
Very cool, thanks for posting that. I'll add it to the list. 20MY Defender 110 Fuji White
Hairy Dan Member Since: 25 Apr 2013 Location: NW Durham Posts: 1448 ![]() ![]() ![]() |
Just bringing the list up to date to save people searching through the thread for settings
- Activate WIFI/WLAN Hotspot MultiCAN-814 IVIWiFiHotspot Standard: Not fitted Changed to: Internal WiFi Hotspot fitted - Change Splash Screen to "Defender 007" EUCD-205 Racing Sub Brand Standard: Mainstream Vehicle Changed to: LTD 007 - Dynamic Mode EUCD-245 Dynamic-I Standard: Dynamic-i Not Fitted Changed to: Dynamic-i Content with Configurable Dynamic Mode Screen MultiCAN-562 DynamicProgMode Standard: Not available for selection Changed to: Available for selection without timeout Other possible value: Available for selection with timeout MultiCAN-605 ConfigDynamicMode Standard: Not Fitted Changed to: Fitted -Remember Stop/start setting MultiCAN-566 MHLastUserMode = Enabled -WalkAwayLocking MultiCAN-505 Change it to Current: Enabled Only available on MY2023 onward, if you don’t have a locking fuel cap you can enable walk away locking. You will also have to go into your centre screen setting and switch it on -Modify signature LEDs behavior MultiCAN-463 DRLBehWhilstDIsAct Current: Turn Off New: No Action Other possible value: Dim MultiCAN-465 DRLBehWhHazardsAct Current: Turn Off New: No Action Other possible value: Dim This setting is to keep them on while the turn signals or hazard lights are operating. Or only dim them. EUCD-018 Foglight Function Current: Depends on market Other possible values: Foglight without restrictions, Foglight not together with high beam MultiCAN-807 Approach Unlocking from: Disabled to: Enabled MultiCAN-717 Front Belt Minder Beltminder ON (ECE type) Change to off to disable your seatbelt warning buzzer MultiCAN-770 Remote Release Tailgate Enabled This will make the rear door pop open when you press the button on the key fob BUT on mine it pops open and then the soft close mechanism grabs it and closes it again ![]() -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
I know somebody asked about stopping the mirrors to unfold or fold automatically but I can't find the post at the moment, whoever it was may like to have a play about with this setting and see if that works how you want it
![]() MultiCAN-703 Exterior Mirror Auto Unfold Automatic External Mirrors Unfold Enabled If it does report back and let us know ![]() -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
That was me! l've got the unit on the way to me so will have a look at that when l get a chance, and report back on here.
lf l disable the auto fold/unfold then hopefully they will still work using the buttons on the inside of the door. As there are some occasions when l do need to fold the mirrors. A complete mirror assembly (mirror with housing, arm and swivel) on my old Defender was £25. l imagine this one costs a bit more than that. |
![]() ![]() ![]() -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
Nicofender Member Since: 16 Jan 2023 Location: Southern Posts: 51 ![]() ![]() |
That's pretty neat! Tried both and both work well. I don't have the soft close doors but when I just press the button the door keeps staying in its "safety position" not closed yet not open. So when you push against the door from the inside and press the button then, the door opens. It's magic! Sleeping in the Fender just got so much better! Anyone tried to activate ACC since the new update? |
OVRLANDR Member Since: 16 May 2022 Location: New York Posts: 45 ![]() ![]() |
I have tried to enact ACC since the update. These are the CCF’s I changed:
EUCD - 023 Cruise Control Old - Without Cruise Control New - Adaptive Cruise Control MultiCAN - 497 IntelEmerBrkingCUIB Old - IEB not Fitted New - IEB Fitted MultiCAN - 580 PTCruiseFitment Old - Normal Cruise Fitted New - ACC with Queue Assist Fitted MultiCAN - 712 ACC Stop Gap Select Old - Not Supported New - No change MultiCAN - 809 ACC Stop Gap Setting Old - Not Fitted New - Fitted When I make these changes, my cruise no longer works as well as the LKA quits. I also still receive the Emergency Braking Disabled 😞 Still chugging away! |
I put all my eggs in their basket for ACC activation. Hope GAP will figure it out soon.
l've received my GAP tool today!
The operation of the tool seems quite involved, the instructions are online and run to 185 A4 pages. As a minimum l've had to print pages 34-65 which seems to be the setup instructions. As a lot of the pages have text boxes it uses a lot of printer ink, l don't fancy trying to read it all on my ipad, particularly as it's the same device l will be using to operate the tool. Hopefully once l download it all l'll be able to make sense of it. ![]() Click image to enlarge |
walfy Member Since: 29 Aug 2007 Location: Frome Posts: 2702 ![]() ![]() |
I'm still toying with the idea of making a purchase.
Do we have a DEFINITIVE list of the options that it will enable 100%? Seems a lot of people are having mixed results. I want it to work and I want to buy one but if I can't be 100% sure of the results I'll get then it makes the purchase a bit more risky 110 D250 SE HT 110 USW SOLD RRE HSE Dynamic Gone, wife killed it VOLVO XC60 R Dynamic with some toys Polaris RZR 900XP SOLD |
